Posted Mon 07 Apr 14 @ 8:14 am
Hi, it's been over a month talking about dual screen monitor problem in mac and i get irrelevant answers so far.
Please answer me with straight words. Will it be a fix and if so when?
If you do not have a real answer please do not attempt to answer me.
I would like to have a DEV answer please.
You can read full dialog here:
http://www.virtualdj.com/contact/tickets.html?ticketid=219318
Also i have upload a video showing the problem.
http://rapidshare.com/share/996B9E64DF417602C8BE2290DFE2849B
Thanks
Billarhos
Thanks
Billarhos
Posted Wed 09 Apr 14 @ 3:07 am
This is scaring me!! I am about to purchase a brand new Mac Book Pro tomorrow (which will probably come with the latest Maverick OS) and install the latest Virtual DJ. IS THERE ANY SOLID ADVICE YOU CAN GIVE ME before I make this purchase? I don't want any issues. Thanks in advance!!
Posted Mon 14 Apr 14 @ 3:07 pm
I buy January 2014 the brand new MacBook Pro Retina 15", i7, 16GB, Intel Iris + NVidia GT 750 with 2 GB and I make a configuration buy with the upgrade to 1 TB SSD and 2,6 Processor.
I play only video and have no problems with VDJ.
The only thing I don't understand is why I don't can delete files directly in VDJ ?!
This is my first MacBook and until now I use a windows notebook.
On the Windows Version of VDJ I delete tracks directly in VDJ but on Mac I don't can do that ?!
Why ?!?
Why ?!?
Posted Tue 15 Apr 14 @ 1:05 am
I thought the "Retina Display" Macbooks were not upgradeable because of the way they are built? IS this not true?
Posted Tue 15 Apr 14 @ 3:39 pm
Guess he means he has bought it from Apple side with the 1TB SSD instead of the 512GB.
Posted Wed 16 Apr 14 @ 5:45 am
Exactly Haui and with the 2,6 Processor
Haui any Idea about the Delete problem ?!
Posted Wed 16 Apr 14 @ 8:28 am
This is a known bug and i'm sure it will be fixed with V8. :-)
You can delete a single file, but when you select more then one it will not work.
Posted Wed 16 Apr 14 @ 9:03 am
Got it, thanks!
Posted Wed 16 Apr 14 @ 11:38 am
I just got a new Mac Book Pro. I've been on Windows for years and wanted to do the switch. Before I was using Music Express with Virtual DJ to drag songs in from my external hard drive and running my shows like that. Now that I have Mac I'm trying to find a good music catalog software (besides I-Tunes) that will work the same. Does anybody have any ideas on what software will do that? I've tried Parallels to run my windows with Mac but it was a fail.
Posted Sun 04 May 14 @ 7:07 am
I just installed the new Mavericks upgrade and now I can get my Alesis Multimix 8 to work properly with my Virtual Dj. Its says the Coreaudio is not configured properly or the usb is connected. It was connected the right way and I used the same settings as I did the day before. Is anyone know why this is happening? Can it be fixed or do I have to revert back to the OS before? Can someone help, I use this to broadcast with.
Posted Wed 07 May 14 @ 11:36 pm
VDJ 7.4 will not open after install. I have a fairly new mac mini, and I had VDJ 7.4 installed on it before, but stupidly accidental partitioned over it, forcing me to re-install Mavericks. Since I only had VDJ on that instance of Mavericks on that OS, it wasn't much trouble to start over. But when I reinstalled the OS, then VDJ, VDJ would not come up. I tried VDJ 8 but it says "File Not Found". BTW, I have NI Audio 2 DJ as my sound interface. Those two things are the only programs I have installed.
I must be missing a component crucial to VDJ. What should I do?
Thanks
Thanks
Posted Fri 16 May 14 @ 11:39 pm
Thanks
Thanks
Same problem here - need help! same on my imac and my macbook pro late 2008!!!
pls help - i need it
Posted Sat 14 Jun 14 @ 3:37 pm
Maddihni
Please tell us which version on VDJ8 you are running and which version of OSX your mac is running.
Posted Sun 15 Jun 14 @ 5:14 am
Wuts up my music lovers I just got a mac and cannot find my music after migrating from pc to MacBook pro using os maverick
Posted Sun 22 Jun 14 @ 4:57 pm
i had vdj 7.4.1 working on osx mavericks 10.9.3 before reinstall...
after reinstall i got this problem! i tried out on leopard, snow leopard, mountain lion and mavericks...
...all osx was a full and clean install without backup! its the only partition on my mac and the HDD was formated before any install!
user is admin but i also tried as root!
there is allways this error!
when i tried the vdj8 there is allways "file not found" when i try to open :(
the vdj 7 has this report on each osx system i tried:
Process: VirtualDJ Pro Full [252]
Path: /Applications/VirtualDJ Pro Full.app/Contents/MacOS/VirtualDJ Pro Full
Identifier: com.atomixproductions.virtualdjprofull
Version: 7.4.1 (7.4.1)
Code Type: X86 (Native)
Parent Process: launchd [101]
Date/Time: 2014-06-23 19:28:02.644 +0200
OS Version: Mac OS X 10.6 (10A432)
Report Version: 6
Interval Since Last Report: 876 sec
Crashes Since Last Report: 2
Per-App Interval Since Last Report: 1 sec
Per-App Crashes Since Last Report: 2
Anonymous UUID: D477F610-E00E-424A-8187-68414DFE0146
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Application Specific Information:
*** Terminating app due to uncaught exception 'NSInvalidArgumentException', reason: '*** +[NSString stringWithUTF8String:]: NULL cString'
*** Call stack at first throw:
0 CoreFoundation 0x97e3158a __raiseError + 410
1 libobjc.A.dylib 0x9371bf49 objc_exception_throw + 56
2 CoreFoundation 0x97e312b8 +[NSException raise:format:arguments:] + 136
3 CoreFoundation 0x97e3122a +[NSException raise:format:] + 58
4 Foundation 0x9862c4b5 +[NSString stringWithUTF8String:] + 102
5 VirtualDJ Pro Full 0x000ecadf -[RegInterfaceController awakeFromNib] + 51
6 CoreFoundation 0x97dcada4 -[NSSet makeObjectsPerformSelector:] + 196
7 AppKit 0x96a335d2 -[NSIBObjectData nibInstantiateWithOwner:topLevelObjects:] + 1566
8 AppKit 0x96a315aa loadNib + 257
9 AppKit 0x96a309a4 +[NSBundle(NSNibLoading) _loadNibFile:nameTable:withZone:ownerBundle:] + 228
10 AppKit 0x96a308b5 +[NSBundle(NSNibLoading) loadNibFile:externalNameTable:withZone:] + 158
11 AppKit 0x96a30800 +[NSBundle(NSNibLoading) loadNibNamed:owner:] + 383
12 VirtualDJ Pro Full 0x00062b16 _Z14AskSerialCocoav + 111
13 VirtualDJ Pro Full 0x001017bd _Z9AskSerialv + 43
14 VirtualDJ Pro Full 0x0013803c main + 306
15 VirtualDJ Pro Full 0x000257ea start + 54
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
0 com.apple.CoreFoundation 0x97e7bb07 ___TERMINATING_DUE_TO_UNCAUGHT_EXCEPTION___ + 7
2 com.apple.CoreFoundation 0x97e312b8 +[NSException raise:format:arguments:] + 136
3 com.apple.CoreFoundation 0x97e3122a +[NSException raise:format:] + 58
4 com.apple.Foundation 0x9862c4b5 +[NSString stringWithUTF8String:] + 102
5 ...roductions.virtualdjprofull 0x000ecadf -[RegInterfaceController awakeFromNib] + 51
6 com.apple.CoreFoundation 0x97dcada4 -[NSSet makeObjectsPerformSelector:] + 196
7 com.apple.AppKit 0x96a335d2 -[NSIBObjectData nibInstantiateWithOwner:topLevelObjects:] + 1566
8 com.apple.AppKit 0x96a315aa loadNib + 257
9 com.apple.AppKit 0x96a309a4 +[NSBundle(NSNibLoading) _loadNibFile:nameTable:withZone:ownerBundle:] + 228
10 com.apple.AppKit 0x96a308b5 +[NSBundle(NSNibLoading) loadNibFile:externalNameTable:withZone:] + 158
11 com.apple.AppKit 0x96a30800 +[NSBundle(NSNibLoading) loadNibNamed:owner:] + 383
12 ...roductions.virtualdjprofull 0x00062b16 AskSerialCocoa() + 111
13 ...roductions.virtualdjprofull 0x001017bd AskSerial() + 43
14 ...roductions.virtualdjprofull 0x0013803c main + 306
15 ...roductions.virtualdjprofull 0x000257ea start + 54
Thread 1: Dispatch queue: com.apple.libdispatch-manager
0 libSystem.B.dylib 0x929e010a kevent + 10
1 libSystem.B.dylib 0x929e0824 _dispatch_mgr_invoke + 215
2 libSystem.B.dylib 0x929dfce1 _dispatch_queue_invoke + 163
3 libSystem.B.dylib 0x929dfa86 _dispatch_worker_thread2 + 234
4 libSystem.B.dylib 0x929df511 _pthread_wqthread + 390
5 libSystem.B.dylib 0x929df356 start_wqthread + 30
Thread 2:
0 libSystem.B.dylib 0x929df1a2 __workq_kernreturn + 10
1 libSystem.B.dylib 0x929df738 _pthread_wqthread + 941
2 libSystem.B.dylib 0x929df356 start_wqthread + 30
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x00000000 ebx: 0x9371bf25 ecx: 0xa03dc500 edx: 0x0000003b
edi: 0xa0491ab0 esi: 0x01723dc0 ebp: 0xbffff3f8 esp: 0xbffff3e0
ss: 0x0000001f efl: 0x00000282 eip: 0x97e7bb07 cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
cr2: 0x021f8000
Binary Images:
0x1000 - 0xa12ff7 +com.atomixproductions.virtualdjprofull 7.4.1 (7.4.1) <9F619E6F-C252-0012-E150-FC3B51BF0C11> /Applications/VirtualDJ Pro Full.app/Contents/MacOS/VirtualDJ Pro Full
0x156c000 - 0x1621fe7 libcrypto.0.9.7.dylib ??? (???) <4917E4F2-817F-5AC4-3FBE-54BC96360448> /usr/lib/libcrypto.0.9.7.dylib
0x1667000 - 0x16b3fff com.apple.audio.midi.CoreMIDI 1.7 (42) <670CB7F9-AA00-86F3-6623-E1335F7AEA83> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x8fe00000 - 0x8fe4162b dyld 132.1 (???) <211AF0DD-42D9-79C8-BB6A-1F4BEEF4B4AB> /usr/lib/dyld
0x90003000 - 0x901bffef com.apple.ImageIO.framework 3.0.0 (3.0.0) <A37E541F-3D6A-2BE9-AB32-F60CCDE13608> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x901f7000 - 0x902edff7 libGLProgrammability.dylib ??? (???) <B8E40851-3A01-7D01-2F96-537BF7FA63B5> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x9035c000 - 0x90366ff7 libCSync.A.dylib ??? (???) <A05BB12D-CD51-DE43-323B-3A3E99A3EED5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x90816000 - 0x90858fe7 libvDSP.dylib ??? (???) <8F8FFFB3-81E3-2969-5688-D5B0979182E6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x90859000 - 0x90879fe7 libresolv.9.dylib ??? (???) <A48921CB-3FA7-3071-AF9C-2D86FB493A3A> /usr/lib/libresolv.9.dylib
0x9087f000 - 0x90882ff7 libCGXType.A.dylib ??? (???) <3FB5E457-EABF-B33E-E01B-C695FB2D72EE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x908da000 - 0x908ddff7 libCoreVMClient.dylib ??? (???) <16BB2178-B32D-E57E-F1E4-D177F7754232> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x908e9000 - 0x9092aff7 libRIP.A.dylib ??? (???) <6DB158C6-A84D-98C9-1D48-868A3DB17D09> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x90cbe000 - 0x90d70ffb libFontParser.dylib ??? (???) <EB089832-660F-0B34-3AC8-CCDA937987D9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x90e95000 - 0x90f15feb com.apple.SearchKit 1.3.0 (1.3.0) <9E18AEA5-F4B4-8BE5-EEA9-818FC4F46FD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x90fa0000 - 0x90faaffb com.apple.speech.recognition.framework 3.10.10 (3.10.10) <E106CC3A-7633-5587-0B29-64E19FCBC613> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x90fab000 - 0x90fdfff7 libcups.2.dylib ??? (???) <9078BA07-DEE1-6597-D15D-7BE3A20CB5A0> /usr/lib/libcups.2.dylib
0x90fe0000 - 0x91062ffb SecurityFoundation ??? (???) <29C27E0E-B2B3-BF6B-B1F8-5783B8B01535> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x91063000 - 0x910a9ff7 libauto.dylib ??? (???) <FAB17F30-A28B-E33D-6E21-C7119C9C83ED> /usr/lib/libauto.dylib
0x910aa000 - 0x910d2ff7 libxslt.1.dylib ??? (???) <769EF4B2-C1AD-73D5-AAAD-1564DAEA77AF> /usr/lib/libxslt.1.dylib
0x910d3000 - 0x9117bff7 com.apple.QD 3.31 (???) <40FCAC85-4E4F-2290-90D4-F66D550ADFDC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x9117c000 - 0x9117cff7 com.apple.Carbon 150 (152) <608A04AB-F35D-D2EB-6629-16B88FB32074> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x91305000 - 0x9173aff7 libLAPACK.dylib ??? (???) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x9173b000 - 0x917eaff3 com.apple.ink.framework 1.3 (104) <8526D880-D367-3EF9-DBFD-9A6AB240F57A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x91886000 - 0x918a1ff7 libPng.dylib ??? (???) <38DD4AA1-0643-85A0-F2F5-EE9269729975> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x918a2000 - 0x918baff7 com.apple.CFOpenDirectory 10.6 (10.6) <1537FB4F-C112-5D12-1E5D-3B1002A4038F> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x918bb000 - 0x918cffe7 libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib
0x918d0000 - 0x9193fff7 libvMisc.dylib ??? (???) <59243A8C-2B98-3E71-8032-884D4853E79F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x9195a000 - 0x919ebfe3 com.apple.print.framework.PrintCore 6.0 (312) <C588530A-0F2C-DD72-E308-3B8735125189> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x919ec000 - 0x91aedfe7 libxml2.2.dylib ??? (???) <C242A74D-280A-90C3-3F79-891624AA45D2> /usr/lib/libxml2.2.dylib
0x91aee000 - 0x91aefff7 com.apple.audio.units.AudioUnit 1.6 (1.6) <68180B96-381C-A09D-5576-606A134FD953> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x91af1000 - 0x91b41fe7 libGLU.dylib ??? (???) <55A69DCE-1237-341E-F239-CDFE1F5B19BB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x91b42000 - 0x91c1dfef com.apple.DesktopServices 1.5.0 (1.5.0) <5295C246-805B-DBCD-BA61-1AE9A458CF73> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x91c27000 - 0x91c28ff7 com.apple.TrustEvaluationAgent 1.0 (1) <71E2DA16-83EC-6056-FFEE-862A04B5599F> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x91c29000 - 0x91e8bff3 com.apple.security 6.0 (36910) <F045B57C-054F-F06F-EF7E-EABEC2700274> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x91edd000 - 0x91ee4fff com.apple.print.framework.Print 6.0 (237) <7A06B15C-B835-096E-7D96-C2FE8F0D21E1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x91fc1000 - 0x91fcaff7 com.apple.DiskArbitration 2.3 (2.3) <E9C40767-DA6A-6CCB-8B00-2D5706753000> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x921a7000 - 0x921cbff7 libJPEG.dylib ??? (???) <265DBF67-994E-E320-4CB1-9C3DE792C3B2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x9231d000 - 0x92323fff com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x92324000 - 0x92367ff7 com.apple.NavigationServices 3.5.3 (181) <28CDD978-030E-7D4A-5334-874A8EBE6C29> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x923a4000 - 0x923e8fe7 com.apple.Metadata 10.6.0 (507.1) <CBD1B22B-5F10-C784-03A2-35106B97DF3F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x92402000 - 0x92402ff7 com.apple.vecLib 3.5 (vecLib 3.5) <17BEEF92-DF30-CD52-FD65-0B7B43B93617> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x92403000 - 0x92403ff7 com.apple.Cocoa 6.6 (???) <EA27B428-5904-B00B-397A-185588698BCC> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x92404000 - 0x9281aff7 libBLAS.dylib ??? (???) <C4FB303A-DB4D-F9E8-181C-129585E59603> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x9281b000 - 0x92822ff7 com.apple.agl 3.0.12 (AGL-3.0.12) <6BF89127-C18C-27A9-F94A-981836A822FE> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x9282e000 - 0x92831ffb com.apple.help 1.3.1 (41) <67F1F424-3983-7A2A-EC21-867BE838E90B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x92832000 - 0x92836ff7 libGIF.dylib ??? (???) <51848EBF-27D4-0F85-C22A-D1AE10D328F3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x929b9000 - 0x92b5dfeb libSystem.B.dylib ??? (???) <068CC3F2-F867-A231-A16C-CC01C29A9816> /usr/lib/libSystem.B.dylib
0x92b5e000 - 0x92c2fff3 ColorSyncDeprecated.dylib ??? (???) <AFD6DAC8-12EF-B2A0-5322-E902D5B48B0A> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
0x92c30000 - 0x92c74ff3 com.apple.coreui 0.2 (112) <A810DFFD-6314-5E2B-93A4-D5626634B1EE> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x92cb4000 - 0x92cc2fe7 libz.1.dylib ??? (???) <7B7A02AB-DA99-6180-880E-D28E4F9AA8EB> /usr/lib/libz.1.dylib
0x92cc3000 - 0x92ce9fff com.apple.DictionaryServices 1.1 (1.1) <07694B30-56A9-5C98-B8BC-DA0628715FA8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x92cea000 - 0x92e6cfe7 libicucore.A.dylib ??? (???) <FBB66376-CBA9-8149-A1AA-10AB8578C3B3> /usr/lib/libicucore.A.dylib
0x92e6d000 - 0x9318cfe7 com.apple.CoreServices.CarbonCore 859.1 (859.1) <2E72AF56-4BE6-294A-7372-19C360688B8B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x9318d000 - 0x93190fe7 libmathCommon.A.dylib ??? (???) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
0x93191000 - 0x931cbfe7 libFontRegistry.dylib ??? (???) <EE633CF6-8827-EF05-10A4-5F2937120227> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x93305000 - 0x93305ff7 com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x93306000 - 0x933a2fe7 com.apple.ApplicationServices.ATS 4.0 (???) <81700C90-2614-F7E2-CC6A-B01C24A2BD75> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x933a3000 - 0x933b8fff com.apple.ImageCapture 6.0 (6.0) <3F31833A-38A9-444E-02B7-17619CA6F2A0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x933f9000 - 0x934a8fef com.apple.ColorSync 4.6.0 (4.6.0) <66ABAE86-B0EC-D641-913D-08ACA965F9FA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x934c4000 - 0x9352efe7 libstdc++.6.dylib ??? (???) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
0x9352f000 - 0x93589ff7 com.apple.framework.IOKit 2.0 (???) <7618DDEC-2E3B-9C6E-FDC9-15169E24B4FB> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x9358b000 - 0x935aafe7 com.apple.opencl 11 (11) <372A42E7-FB10-B74D-E1A0-980E94D07021> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x935ec000 - 0x9364cfe7 com.apple.CoreText 3.0.0 (???) <8F4FCAE2-8E6F-F0DE-A6AA-15D0228B7F13> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x9364d000 - 0x9369afeb com.apple.DirectoryService.PasswordServerFramework 6.0 (6.0) <BF66BA5D-BBC8-78A5-DBE2-F9DE3DD1D775> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
0x9369b000 - 0x936d8ff7 com.apple.SystemConfiguration 1.10 (1.10) <897AEEAF-CF5D-2843-C33B-31A0A7C98A6A> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x93712000 - 0x937bffe7 libobjc.A.dylib ??? (???) <410DD065-A18F-F054-0457-65525F4D1039> /usr/lib/libobjc.A.dylib
0x93a88000 - 0x93abbff7 com.apple.AE 496 (496) <B638FDD4-7322-F0E4-ACEB-777D8A1399E1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x93abc000 - 0x93b54fe7 edu.mit.Kerberos 6.5.8 (6.5.8) <BA9BD282-FF56-3BFD-E78C-7DBE73B48480> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x93b55000 - 0x93b57ff7 com.apple.securityhi 4.0 (36638) <962C66FB-5BE9-634E-0810-036CB340C059> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x93b58000 - 0x93bbcffb com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x93bbd000 - 0x93bbdff7 com.apple.Accelerate 1.5 (Accelerate 1.5) <F642E7A0-3720-FA19-0190-E6DBD9EF2D9B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x93bc5000 - 0x93f29ff7 com.apple.QuartzCore 1.6.0 (226.0) <7E29DD09-BE04-AA06-5C81-5C093F16901B> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x93f2a000 - 0x93fc7ff3 com.apple.LaunchServices 360.3 (360.3) <C8590D53-E46A-F58A-7CF2-03A8159D8569> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x94148000 - 0x94929497 com.apple.CoreGraphics 1.535.5 (???) <0B93D29C-D957-AD00-10F3-94112D75D6D9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x94a05000 - 0x94a27ff3 com.apple.DirectoryService.Framework 3.6 (621) <61569C79-6567-BE8F-4F76-BAC04E5FBF79> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x94aa0000 - 0x94d99fef com.apple.QuickTime 7.6.3 (1584) <687233E1-F428-5224-08D5-5874BEA2300D> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x94f7b000 - 0x94f8dff7 com.apple.MultitouchSupport.framework 200.20 (200.20) <1D7EE15B-ADDD-1F57-F1FB-FB5252910D5A> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x94fd5000 - 0x94fe6ff7 com.apple.LangAnalysis 1.6.5 (1.6.5) <E77440D0-76EE-EB4C-3D00-9EDE417F13CF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x95141000 - 0x951fafe7 libsqlite3.dylib ??? (???) <16CEF8E8-8C9A-94CD-EF5D-05477844C005> /usr/lib/libsqlite3.dylib
0x951fb000 - 0x952c5fef com.apple.CoreServices.OSServices 352 (352) <D9F21CA4-EED0-705F-8F3C-F1322D114B52> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x952ce000 - 0x952ffff7 libGLImage.dylib ??? (???) <0FB347C7-A579-4E51-4733-39AB28064554> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x95300000 - 0x9530afe7 com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x9530b000 - 0x9530fff7 IOSurface ??? (???) <C11D3FF3-EB51-A07D-EF24-9C2004115724> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x95310000 - 0x95312ff7 libRadiance.dylib ??? (???) <0E03CF64-0931-7B9A-F617-4387B809D6D8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x95318000 - 0x95318ff7 com.apple.CoreServices 44 (44) <AC35D112-5FB9-9C8C-6189-5F5945072375> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x95340000 - 0x9534aff7 libGL.dylib ??? (???) <B375A3B6-2983-A4E4-50FB-9087FD606FD6> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x953ba000 - 0x953c7ff7 com.apple.opengl 1.6.3 (1.6.3) <59D86286-B46F-B0E4-68F8-E5CDCADE393E> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x96357000 - 0x96357ff7 com.apple.Accelerate.vecLib 3.5 (vecLib 3.5) <3E039E14-2A15-56CC-0074-EE59F9FBB913> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x96358000 - 0x96435ff7 com.apple.vImage 4.0 (4.0) <64597E4B-F144-DBB3-F428-0EC3D9A1219E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x9648d000 - 0x96491ff7 libGFXShared.dylib ??? (???) <ED62E870-E219-C873-88AA-9CE08108F811> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x964f3000 - 0x9653cfe7 libTIFF.dylib ??? (???) <6EF87001-6FB4-1405-C588-F6D8042D3534> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x9653d000 - 0x9654aff7 com.apple.NetFS 3.2 (3.2) <E6FD80B0-0238-0C42-A3EC-EBDEC107A1C3> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x96901000 - 0x96a2afe7 com.apple.audio.toolbox.AudioToolbox 1.6 (1.6) <62BEEBE6-68FC-4A48-91CF-39DA2BD793F1> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x96a2b000 - 0x97307ff7 com.apple.AppKit 6.6 (1038) <25DDEBFC-8A2F-8434-1D97-AEC55B5205F8> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x97bd2000 - 0x97c22ff7 com.apple.framework.familycontrols 2.0 (2.0) <50617342-E578-4C1C-938A-19A37ECA91CA> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x97c6c000 - 0x97d5eff7 libcrypto.0.9.8.dylib ??? (???) <792B8722-3091-5E9F-E25F-67499CFE0599> /usr/lib/libcrypto.0.9.8.dylib
0x97d5f000 - 0x97ed6fef com.apple.CoreFoundation 6.6 (550) <193E33D6-2E92-3452-773B-60A1A9CCC573> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x98175000 - 0x981c6ff7 com.apple.HIServices 1.8.0 (???) <B8EC13DB-A81A-91BF-8C82-66E840C64C91> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x98629000 - 0x98899ffb com.apple.Foundation 6.6 (751) <A61B645E-1A15-5BCA-3043-C8AB85C6AD30> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x9889a000 - 0x988b9fe3 libexpat.1.dylib ??? (???) <82E6F83F-9667-2E39-1D9D-4A49C642527D> /usr/lib/libexpat.1.dylib
0x988ba000 - 0x988d6fe3 com.apple.openscripting 1.3 (???) <D2FF4419-FD71-5D4A-F397-B03E82085232> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x988d9000 - 0x98980fe7 com.apple.CFNetwork 454.4 (454.4) <7C563385-9893-3B48-8607-5BC81DA2C4CF> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x98981000 - 0x98981ff7 liblangid.dylib ??? (???) <B99607FC-5646-32C8-2C16-AFB5EA9097C2> /usr/lib/liblangid.dylib
0x989dd000 - 0x989eaff7 libbz2.1.0.dylib ??? (???) <495732E1-2AC4-44FC-E633-4CBCC503B924> /usr/lib/libbz2.1.0.dylib
0x98be8000 - 0x98bf4ff7 libkxld.dylib ??? (???) <152C8DBB-0149-5827-3240-E57CA85CFE5F> /usr/lib/system/libkxld.dylib
0x98bf5000 - 0x98d1dfe7 com.apple.CoreData 102 (246) <E7E6CE39-9B51-13C8-FE31-8FE57CF7BDE1> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x98f31000 - 0x98f4fff7 com.apple.CoreVideo 1.6.0 (43.0) <3A853574-DD9E-08D8-FD2C-6221B55C3E08> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x98f50000 - 0x99273fef com.apple.HIToolbox 1.6.0 (???) <6F95AF67-678A-D8BC-FFC2-029C9AA2F44A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x99274000 - 0x99368fe7 libiconv.2.dylib ??? (???) <0C578460-3929-29DD-585A-DB1E0C977425> /usr/lib/libiconv.2.dylib
0x9936c000 - 0x9937cff7 libsasl2.2.dylib ??? (???) <C8744EA3-0AB7-CD03-E639-C4F2B910BE5D> /usr/lib/libsasl2.2.dylib
0x9937d000 - 0x993f6ff3 com.apple.audio.CoreAudio 3.2.0 (3.2) <91AE891E-6015-AABE-3512-2D5EBCA0937B> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x993f7000 - 0x9940bffb com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x99419000 - 0x9941eff7 com.apple.OpenDirectory 10.6 (10.6) <92582807-E8F3-3DD9-EB42-4195CFB754A1> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0xffff0000 - 0xffff1fff libSystem.B.dylib ??? (???) <068CC3F2-F867-A231-A16C-CC01C29A9816> /usr/lib/libSystem.B.dylib
Model: MacBookPro5,3, BootROM MBP53.00AC.B03, 2 processors, Intel Core 2 Duo, 2.8 GHz, 8 GB, SMC 1.48f2
Graphics: NVIDIA GeForce 9600M GT, NVIDIA GeForce 9600M GT, PCIe, 512 MB
Graphics: NVIDIA GeForce 9400M, NVIDIA GeForce 9400M, PCI, 256 MB
Memory Module: global_name
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8D), Broadcom BCM43xx 1.0 (5.10.91.19)
Bluetooth: Version 2.2.0f18, 2 service, 1 devices, 1 incoming serial ports
Network Service: AirPort, AirPort, en1
Serial ATA Device: OWC Mercury Extreme Pro SSD, 111,79 GB
Serial ATA Device: MATSHITADVD-R UJ-868, 7,24 GB
USB Device: Built-in iSight, 0x05ac (Apple Inc.), 0x8507, 0x24400000
USB Device: Apple Internal Keyboard / Trackpad, 0x05ac (Apple Inc.), 0x0237, 0x04600000
USB Device: IR Receiver, 0x05ac (Apple Inc.), 0x8242, 0x04500000
USB Device: Internal Memory Card Reader, 0x05ac (Apple Inc.), 0x8403, 0x26500000
USB Device: BRCM2046 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0x06100000
USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x8213, 0x06110000
Report Version: 6
Thread 2:
cr2: 0x021f8000
Binary Images:
Posted Mon 23 Jun 14 @ 12:28 pm
after lots of try - i simply installed VDJ 7 and 8 on Mavericks... just change the place for installation... it works when i install it on a external usb HDD and on external USB stick, too!
its weird! i cant understand this!
but now its working... but allways 1 used USB port!
can someone tell me how i can change the path for ituneslibrary in VDJ 8 ? cant find a registery tool!
Greetz!
MAddihni
Greetz!
MAddihni
Posted Thu 26 Jun 14 @ 2:48 pm
Open the VDJ Config and select OPTION.
Then search just for iTunes :-)
Posted Fri 27 Jun 14 @ 3:42 am
Just got a macbook and a very important feature is no longer available to me now and that is to "RECURSE" a folder? Im running 7.4 still and that has been a life savor for me. any idea's on what to do to get this back? Thanks in advance
Posted Mon 07 Jul 14 @ 12:14 pm
This feature has never been supported in VirtualDJ v7.4.1 and earlier for Mac.
Please see http://www.virtualdj.com/wiki/Mac%20No%20Recurse.html
Posted Mon 07 Jul 14 @ 12:40 pm
