Is Virtual DJ 7.4 compatible with OS X Mavericks?
Posted Tue 22 Oct 13 @ 6:12 pm
Yes it is. Running Mavericks here and works just fine. However, have in mind that the latest OSX versions were more demanding in RAM. 4GB may not be enough
Posted Tue 22 Oct 13 @ 8:43 pm
I have 16gb, so I should be fine.
Thanks!
Thanks!
Posted Tue 22 Oct 13 @ 8:44 pm
Thanks!
Thanks!
All good?
Posted Wed 23 Oct 13 @ 9:32 am
I am also wondering, was about to upgrade but i thought i would check and make sure its working good on mavricks. Same with my external sound card and controller. Ya never know! lol
Posted Wed 23 Oct 13 @ 10:52 am
I'm running 4gb of RAM and audio is fine but the wave bar and graphics are a little jurky, when scrolling music list.
Posted Thu 24 Oct 13 @ 1:16 pm
I think that's just a Mac thing. I'm running an i7 with 8 gigs and my waves never seem smooth.
Posted Thu 24 Oct 13 @ 2:30 pm
Everything works fine on my Mid-2012 15" MacPro. No performance difference at all. I have never had and glitchiness with the graphics.
Posted Thu 24 Oct 13 @ 6:50 pm
Broadcaster 7.4 won't launch on my just updated version of Mavericks.... help!!!! :)
here is what the error details say.. followed by pages and pages of error codes..
Process: VirtualDJ Broadcaster [496]
Path: /Applications/VirtualDJ Broadcaster.app/Contents/MacOS/VirtualDJ Broadcaster
Identifier: com.atomixproductions.virtualdjbroadcaster
Version: 7.4 (7.4)
Code Type: X86 (Native)
Parent Process: launchd [160]
Responsible: VirtualDJ Broadcaster [496]
User ID: 501
Date/Time: 2013-10-25 23:28:03.287 -0400
OS Version: Mac OS X 10.9 (13A603)
Report Version: 11
Anonymous UUID: C9E5F3FF-9653-7A06-39A1
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x00000000c0000000
Version: 7.4 (7.4)
User ID: 501
Report Version: 11
Posted Fri 25 Oct 13 @ 10:31 pm
i am having the same problem, vdj would not start. i'm having he exact same error message as above
Posted Sat 26 Oct 13 @ 8:33 pm
Try removing your plist as detailed here and see if that helps:
http://www.virtualdj.com/wiki/Mac%20Clean%20Re-install.html
Posted Sun 27 Oct 13 @ 6:58 am
I have the same problem... and erasing the file didn't solve it...
Posted Wed 30 Oct 13 @ 8:44 pm
Already re-installed the software and still... all in the latest versions and with all updates!
Posted Wed 30 Oct 13 @ 8:46 pm
The error I get is the following:
Process: VirtualDJ Pro Full [611]
Path: /Applications/VirtualDJ Pro Full.app/Contents/MacOS/VirtualDJ Pro Full
Identifier: com.atomixproductions.virtualdjprofull
Version: 7.4 (7.4)
Parent Process: launchd [231]
Responsible: VirtualDJ Pro Full [611]
User ID: 501
Date/Time: 2013-10-31 01:56:35.445 +0000
Report Version: 11
Anonymous UUID: BD05EA4C-30F9-9BC3-2219-100DE5736776
VM Regions Near 0xc0000000:
Stack 00000000bf800000-00000000c0000000 [ 8192K] rw-/rwx SM=COW
CG shared images 00000000c0001000-00000000c0004000 [ 12K] r--/r-- SM=SHM
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_platform.dylib 0x911a33d5 _platform_memmove$VARIANT$sse42 + 197
1 com.apple.CoreFoundation 0x95700c7e __CFStringCreateImmutableFunnel3 + 2654
2 com.apple.CoreFoundation 0x957159b1 CFStringCreateWithCharacters + 97
And goes on further bellow... not even starting the application!
Anyone found the solution?
Version: 7.4 (7.4)
User ID: 501
Report Version: 11
Posted Wed 30 Oct 13 @ 9:00 pm
hello! i have the virtual dj le version that came with the pioneer wego
i am running:
a mid 2012 mbp 2.3 ghz i7 processor
8 gb of ram
i would like to upgrade to osx mavericks will i need to patch the virtualdj le version? will it work with no issues?
thanks!
p
i am running:
8 gb of ram
thanks!
p
Posted Mon 04 Nov 13 @ 9:03 pm
I'm confident that VDJ7 will work with OS X Mavericks, but anyone tried it with a VMS4? Wondering how it will handle external sound card. I'll install it eventually, but no need to jeopardize a working platform.
Posted Mon 11 Nov 13 @ 11:26 am
Works fine on Macbook Unibody late 2008 with 2,4ghz, 4GB ram and 480GB SSD from Crusial.
Posted Sun 17 Nov 13 @ 7:12 am
I got a new macbook pro retina in this week with mavericks pre installed. I put virtual dj 7.4 on it then 7.4.1 then back to 7.4
Both versions had problems. It seemed that it didnt like it when I set cue points on songs. Im using a numark ns6. No drivers are available yet for this device (as far as I know) for mavericks. I had copied all my music and videos over from my hp laptop to the mac so I could get it all set up to dj. It seemed to run ok as long as I wasnt setting cue points. I decided to go ahead and dj with the macbook last night even though I knew full well It could crash.
After I setup, before I started, I ran a slideshow with some graphics on the tv's. I always do this. After a few minutes It had crashed. So I knew then I could either go get my hp or restart vdj and risk it crashing again. Well I spent 3 g's on a macbook so I went with the macbook. Screw it right? Somehow I managed to dj the whole night, 4 hours, and it didnt crash!! I couldnt believe it.
However, Im going back to my pc tonight. I dont want to deal with it. Ill wait for a better update/ drivers. Anyone else had any similar problems with cue points or it crashing?
The specs on the macbook are 16gb ram, 1 tb flash hd, 2.6 intel quad core, 750 nvidia gpu. I maxed it out. The computer is legit.
Posted Sat 23 Nov 13 @ 3:59 pm
i have been having crashes
like this a lot on mavericks
Posted Mon 25 Nov 13 @ 4:15 pm
I use a Mid 2010 i5 17" MBP with still only 4GB RAM.
Till today i have no issues with Mavericks and 7.4.1. while using audio and/or video.
I have heard from some user which have had problems with crashes or high cpu after the update to Mavericks.
The one who have spoken to me, have solved her problems with a OS reinst.
I mean a OS X inst. from scratch!
Not from timemaschine or any other backup medium.
They just moved from timemaschine after that all the VDJ folder from timemaschine by using the finder.
After that they haven't used the migrationmanager and just installed VDJ for test and the problem was gone.
First time they have used VDJ also as clean as possible, whithout the VDJ folder backup!
Maybe you will try it that way to.
With a timemaschine backup you have nothing to loose.
Posted Tue 26 Nov 13 @ 2:30 am
