Hello.
Im trying to open 2 instances of virtualDJ but its not happening for me at the moment. Is there something i need to enable to achieve this??
The reason i need to do this is thus..
https://virtualdj.com/forums/180882/VirtualDJ_Skins/VirtualTouch_ver_1_1_(4_3_ratio)_skin_engine_glitch.html
Occasionally the browser appears with white bands and is un-readable. im not sure why this happens and i cannot predict when this will happen as 75% of the time i can get through a gig without this happening.
My workaround is that i want to create a multi-instance skin co that i can have 2 decks on standby on screen ready to take over should this browser glitch arise. (then i can safely re-start virtualdj without spoiling the flow)
Posted Mon 21 Oct 13 @ 5:58 pm
I believe this won't work since we can have have 99 decks now. I could be wrong but when 7 was released they did away with the multi instance.
Posted Tue 22 Oct 13 @ 8:38 am
did you try changing the skin then changing it back? you can probably just click on the same skin to refresh it, that's all you do when you are making a skin... other than that I would look at updating or reinstalling your graphic card drivers.
Posted Tue 22 Oct 13 @ 8:46 am
Multi-instance is not available.
I replied to your other thread as well. Driver/Graphics card related imo.
Do you have the skin in maximized mode when this happens ?
Posted Tue 22 Oct 13 @ 9:31 am
Ive replied in the other post to you DJDad
changing TO this skin and FROM it results in a 1 second audio drop out.
as ive mentioned in the skin forum, everything is up-to-date and the windows install is recent and clean. however i'll keep an eye on this as the graphics driver updated recently.
Posted Tue 22 Oct 13 @ 3:02 pm
The audio dropout usually only happens when changing to a different number of decks.
If you change from a 4 deck to a 4 deck skin there should be no problem.
Keith
Keith
Posted Tue 22 Oct 13 @ 3:18 pm
