I have been using the x session controller for 4 years no problem and suddenly cant map it to the software !!!!!!!!!!!
tried both my laptop and my pc with mixed results. HELP HELP HELP
I need this sorted out. can any one out there guide me what to do to sort out mapping for the x session pro
Martin
Martin
Posted Thu 25 Jul 13 @ 6:23 am
M-Audio X-Session Pro is natively mapped. What do you mean you cant map it ?
When launching VirtualDj do you see the device detected with its name in Config->Mappers tab ?
Did you do any kind of firmware update recently ?
Use the Miditrace. http://www.virtualdj.com/download/miditrace.exe
Select the device in both In and Out Windows and press the SEND button. What is the number you receive below ?
Posted Fri 26 Jul 13 @ 6:55 am
