Hi everyone. I recently bought the Peioneer WeGO and am having trouble with the sound. I have it plugged it into my computer and everything is up and running, but there is no sound coming from my computer's speakers. The only sound I get is from my headphones when I plug them into the machine. I was wondering if anyone else was having this problem or if there is a solution. I am a VDJ pro user. Thanks.
Posted Fri 26 Apr 13 @ 6:36 pm
Config
Sound Setup
Output = Advanced Setup
Advanced Config
Master = Wego Output 1&2
Headphone = Wego Output 3&4
Sound Setup
Advanced Config
Posted Sat 27 Apr 13 @ 9:22 am
...in other words when you're using an external device that has a sound card built in (such as a WeGo), the idea is to connect your speakers to the output of that, not your computer.
Posted Sat 27 Apr 13 @ 9:26 am
Pro Full version provides you the ability to listen the Master Output from your computer's sound card (built in speakers) and prelistening from the headphones socket of your controller.
In this case the Advanced Sound Setup should be ..
Master .... Your computer's built in Sound Card ... Outputs 1,2
Headphones... Pioneer WeGO ASIO .... Outputs 3,4
Posted Sun 28 Apr 13 @ 10:33 am
