Topic: Virtual DJ on Microsoft Surface Tablet? - Page: 2
[Change to tablet mode at the top of the screen quochange your te=djSalemUK]has anyone else managed to get this one figured out?
I too have just got a Surface Pro[/quote]
Posted Tue 14 Jul 20 @ 10:07 pm
Hey everyone!
My Surface Pro 7 keeps freezing when using Virtual DJ 2020 on BCD3000
I run it in compatibility mode in windows 8 on my old Dell which is a i5 and 8gb also!?
I find that this keeps happening when I turn on a loop...do you know if there is anyway to modify the buffer settings on the USB??
Any help appreciated!
Posted Sun 11 Apr 21 @ 10:59 am
user21984974 wrote :
My Surface Pro 7 keeps freezing when using BCD3000!
My first guess would be the BCD3000..
Its known for causing freeze issues..
https://www.google.com/search?q=BCD3000+freeze
What drivers are you using? the old drivers are likely not ready for Windows 10 (and were problematic drivers in the first place)
Its a 15 years old controller, not sure what the "fix" was, its been a long time.
Can try optimize the computer for audio (disable bluetooth, wifi etc) and set a decent buffer at the driver.
512 samples buffer (latency) should hopefully do.
https://www.sweetwater.com/sweetcare/mac-pc-optimization/
And might also be worth trying the https://www.asio4all.com generic driver...
Posted Sun 11 Apr 21 @ 11:21 am
