Hello all,
When I broadcast I am want to be able to talk using my internal mic. How ever when I select microphone for input, single output it wont let me choose simple as a soundcard. It makes me choose ASIO which doesn't work and just gives me an error? Help would be appreciated thank you!
Posted Mon 11 Mar 13 @ 6:25 pm
Home Free version is not supporting broadcasting or Microphone Input. If you are using a different product version, please register the serial number of your software to your Account Page .. http://www.virtualdj.com/users/edit.html
The reason the software is switching to ASIO is because it can not find a sound card that has both outputs and inputs. If your computer's built in sound card has both inputs and outputs, then a choice of 4.1 should be available as well. Try to update the drivers of your sound cards. Do not use fake ASIO drivers such as ASIO4ALL etc.
Posted Mon 11 Mar 13 @ 10:07 pm
