paidia exw grapsei polles fores alla to neo 8ema einai poly parakseno. paizw me polla pc kai laptop edw kai 8 xronia, panta me virtual dj. edw kai dyo xronia pio syxna paizw me ena laptop hp i7 kai me vasiki karta mia traktor audio 2 (tin opoia exw sa vasiki kai se alla pc pou xrisimopoiw). teleftaia mou ekane ena provlima me diakopes tin wra pou epaize to programma ena kommati. ekana format alla syxna pykna mou kanei to idio pragma. mono se afto to laptop (to opoio exei kai ta perissotera ''gkazia'' apo ola ta pc pou paizw kai sta opoia ola pane kala). epeidi paizw kai se gamous, alla kai epeidi 8elw na to exw sa vasiko pc, paei kapou to myalo sas oson afora to se ti ofeiletai afto to pragma? dld ksekinaei na paizei (to latency to exw anevasei ekei pou prepei - gia na sas prolavw) kai syxna pykna kanei stigmiaiew diakopes sto kommati. me exei eknevrisei poly to gegonos. efxaristw kai pali!!
Posted Mon 11 Jun 12 @ 6:56 am
Απενεργοποίησε οποιαδήποτε διαχείριση - εξοικονόμηση ενέργειας
Posted Mon 11 Jun 12 @ 7:39 am
yp'opsin oti to provlima symvainei mono me tin traktor audio 2. me kamia alli. me ti maya 44 px den yparxei kanena provlima (to mono 8ema tis maya einai i xamili entasi tis pou se synartisi me ti xamili proenisxysi tou denon dn-x 1100 pou sini8ws xrisimopoiw xreiazomai enisxytes ''terata''). kserei mipws kapoios tis (apodedeigmena omws) swstes ry8miseis tis traktor audio 2? (egw exw :
sample rate : 44100
process buffer : 256 samples
usb buffer : 4 ms
pou simainei :
output latency : 12,7 ms
sample rate : 44100
usb buffer : 4 ms
pou simainei :
Posted Mon 11 Jun 12 @ 7:53 am
mporeis na mou to kaneis ligo pio liana afto phantom?
Posted Mon 11 Jun 12 @ 7:56 am
Ta 4ms pou exeis to USB buffer winai poly xamila kai tha exeis kopsimata ston ixo, akom akia me kala stimeno mixanima. Anevase to gyrw sta 6-8ms. Thewrw oti akoma kai sta 10ms, den tha exeis idiaitero provlima apokrisis.
Posted Mon 11 Jun 12 @ 9:35 am
Βασικά Μπάμπη μιλάει για USB buffer και όχι για audio buffer. Οι επιλογές που δίνει η Audio 2 για το USB buffer είναι 1,2 και 4ms
Υπάρχει ένα θέμα με πολλά laptops και τις audio 2. Η πιο "απλή" λύση που συνήθως λύνει το πρόβλημα είναι η επεξεργασία των ρυθμίσεων ενέργειας ώστε ο υπολογιστής να μην κάνει εξοικονόμηση ενέργειας, ειδικά απο τις θύρες USB. Εαν αυτό δεν δουλέψει τότε υπάρχει μια πληθώρα επιλογών που μπορούν να πειραχτούν στο BIOS για τον ίδιο σκοπό. Εκεί όμως η διαδικασία είναι απλά "δοκιμή και προσευχή" να λυθεί το πρόβλημα.
Υ.Γ.:
Εαν η απενεργοποίηση των ρυθμίσεων εξοικονόμησης ενέργειας δεν έχει αποτέλεσμα δοκίμασε πρώτα να εγκαταστήσεις τους drivers έκδοση 2.Χ που δίνει η NI στο site της πριν αρχίσεις να κάνεις δοκιμές με το BIOS.
Υ.Γ.:
Posted Mon 11 Jun 12 @ 10:08 am
Γειά σας,
Επειδή έχω και εγώ το ίδιο πρόβλημα με την traktor audio 2 (όταν έπαιζα με τα 400αρια ως κάρτα ήχου όλα καλά), θα ήθελα και εγώ να ξέρω ποιές θα πρέπει να είναι οι ρυθμίσεις σε process buffer και usb buffer....Έχω διαβάσει εδώ κάπου πως το latency πρέπει να είναι γύρω στα 10ms...ισχύει?
Εγώ πέραν από κάτι κοψίματα που έχω όταν κάνω loop, μερικές φορές όταν φορτώνω κάποιο κομμάτι, μου κάνει παραμόρφωση, σαν να ρίχνει το pitch του καναλιού που είναι στον αέρα, αλλά για δευτερόλεπτα. Δεν είχα τέτοια θέματα με τα 400αρια και σκέφτομαι μήπως φταίει το usb buffer για την παραμόρφωση. Οπότε όποιος έχει να προτείνει κάτι, καλοδεχούμενο...
Posted Tue 12 Jun 12 @ 6:05 am
egw eimai pleon mia xara afou ekana osa mou eipate paidia. yp'opsin oti eixa kai ena 8ema me to hub pou xrisimopoiw (den einai ftino alla i polyxrisia isws epaikse to rolo tis), alla kai kati poly simantiko einai to oti stin audio 2 (diefkrinisa oti prokeitai gia tin traktor audio 2 kai oxi gia tin audio 2 dj - einai diaforetikes par'oti moiazoun sa dyo stagones nero sxedon) i ypodoxi tou usb kalwdiou einai arketa xalari me apotelesma na mi kanei epafi polles fores. prosoxi, pernei revma i karta alla den ti vlepei to pc. symvainei kai se filous afto kai gi'afto to anaferw opws kai stis dyo pou exw!! telos pantwn pleon einai ola kala (ekana kai tin anava8misi stin 3.0.3 pou vgike prin liges meres!)
file xrimakom egw egrapsa pio panw poies ry8miseis exw se ola mou ta pc kai doulevoun apsoga kai me teleio ixo. to provlima pou dimiourgi8ike ksafnika itan se afto to laptop kai pleon den yfistatai. ara aftes einai kai oi swstes..!! afto pou exeis na kaneis einai na allakseis sigoura tin arxiki ry8misi tou usb buffer pou einai 1 ms wste na exeis output latency panw apo 10 ms, afou se afti (stin arxiki) kai se mena opws kai se olous kanei megali paramorfwsi!! de xreiazetai na kaneis kati allo!!
Posted Tue 12 Jun 12 @ 11:18 pm
ok θα τα δοκιμάσω κ εγώ και μακάρι να λυθεί και σε εμένα το πρόβλημα...σε ευχαριστώ!
Posted Wed 13 Jun 12 @ 3:40 am
DrJekyl να σου κάνω μία ακόμα ερώτηση....πώς έχεις τις εντάσεις στην κάρτα και στο virtual?
Εγώ έχω την κάρτα full, το master του virulal στο 55% και τα faders στο 75%, είναι οκ?
Posted Wed 13 Jun 12 @ 4:15 am
γεια και απο μενα και καλο καλοκαιρι . τελικα επειδη μπερδευτικα λιγο υπαρχουν συγκεκριμενες ρυθμισεις για την καρτα traktor audio 2 την εχω και γω και θελω να μαθω τι γινεται. και κατι ακομα δεν υπαρχει σχεση αναμεσα στι maya 44 και την audio2 σε οτι αφορα τον ηχο. η μια ειναι 16db kai η αλλη στα 24db.
Posted Wed 13 Jun 12 @ 8:23 am
το εξωτερικο hub παιζει ρολλο αν ειναι φθηνο η ακριβο σε οτι αφορα την καρτα βεβαια . εννοειται οτι εχω κανει ολες τις ρυθμισεις για να ειναι τουμπανο το laptop
Posted Wed 13 Jun 12 @ 8:25 am
Συνήθως τα hubs για dj χρήση, ενδείκνυται να είναι powered, δηλαδή να έχουν δικό τους τροφοδοτικό, ώστε να μην επιβαρύνουν επιπλέον τον υπολογιστή. Επίσης καλό θα ήταν, μιας και η κάρτα ήχου έχει υψηλές απαιτήσεις, να μη μπαίνει σε hub, αλλά μόνη της στη πιο γρήγορη θύρα USB του υπολογιστή. Όλα τα άλλα όπως controller, σκληροί δίσκοι κλπ. μπορούν να μπούν πάνω στο hub, εν ανάγκει...
Posted Wed 13 Jun 12 @ 1:41 pm
φιλε dee p εχεις δικιο το ξερω και αυτο κανω. το θεμα μου ειναι οτι εχω 3 θυρες usb οι 2 ειναι usb 3 και στη μοναδικη usb 2 εκει βαζω το hub και ριχνω πανω τη καρτα το κοντρολερ γιατι δεν παιζουν στη θυρα usb 3. τι αλλο μποτω να κανω ? εχεις καμια πληροφορια για την καρτα ηχου?
Posted Thu 14 Jun 12 @ 7:42 am
xrimakom oi entaseis toso sto virtual oso kai stin karta ennoeitai oti einai sto 100 % !!! an xamilwseis ena apo ta dyo i kai ta dyo fysika 8a xreiazesai poly dynatous enisxytes gia na exeis entasi sta ixeia sou. de yparxei logos allwste na ta exeis xamila afou den yparxei kanena 8ema paramorfwsis oute apo to virtual oute apo tin karta!!
Posted Thu 14 Jun 12 @ 1:43 pm
@xrimakom Προσωπικά αποφεύγω να έχω την ένταση στη full, ώστε να έχω "αέρα" και να αποφεύγω παραμορφώσεις. Η συνήθης ρύθμιση για μένα είναι ως εξής:
α) volume faders full (εκεί δεν υπάρχει θέμα παραμόρφωσης)
β) gain faders -2/+1
γ) master volume (software) 60% με 80%
δ) volume κάρτας ήχου 70% με 90%
@dj liakos Τα βήματα που έκανα για το στήσιμο της Audio2dj ήταν τα εξής:
α) Εγκατάσταση drivers και κατόπιν του DPC Latency Checker και LatencyMon
β) Έλεγχος για red bars/ spikes και γενικότερα troubleshooting με απενεργοποίηση υπηρεσιών στο Device Manager
γ) Αφού πέτυχα το επιθυμητό αποτέλεσμα, πειραματισμός με τις ρυθμίσεις της κάρτας από τις μικρότερες σε μεγαλύτερες τιμές.
δ) Και το πιο σημαντικό: Αλλαγή νοοτροπίας. Επειδή η κάρτα δίνει ρύθμιση 1 nanosecond δε σημαίνει ότι πρέπει να το επιτύχω ή ότι είναι σημαντικό. Τιμές όπως 8 και 10 ms είναι άκρως αποδεκτές, χωρίς να γίνεται αισθητή καθυστέρηση στο ανθρώπινο αυτί...
Γενικότερα δεν υπάρχει σε περιβάλλον Windows η ιδανική ρύθμιση για κάρτες ήχου, λόγω πολλών διαφορετικών συνδιασμών hardware και drivers σε κάθε υπολογιστή. Η λύση που απομένει λοιπον είναι try & error...
'Οσο για το USB 3.0 είναι γνωστά τα προβλήματα συμβατότητας. Το μόνο που μου περνά απ΄ το μυαλό, ως λύση ανάγκης, είναι ένα USB3.0 "friendly" Hub με εξόδους USB 2.0...
Posted Thu 14 Jun 12 @ 3:15 pm
@Dee P
Seuxatistw polu, tha dokimasw auta ta sttings thn epomenh fora pou 8a paiksw...
Posted Thu 21 Jun 12 @ 4:05 am
File Dee P hda ta vhmata p ekanes otan omos pame sto latensy mon kai prepei na apenergopoihsoume programmata
pos ta apenergopoioyme kai poia apenergopoioume
Posted Fri 22 Jun 12 @ 4:06 am
Φίλοι καλημέρα.
Χρησιμοποιώ τη Hercules mp3 e2 και προσπάθησα να εγκαταστήσει την κάρτα audio 2 dj αλλά μάταια. Κατέβασμα και τα drivers απο το Internet 7/6 updated αλλά το laptop μου δεν διαβάζει την κάρτα. Έχω κάνει κάτι λάθος στην εγκατάσταση γιατί μόλις συνδεση την κάρτα ηχου , έτρεξε η αυτόματη εγκατάσταση αλλά δεν ήταν επιτυχής. Χρησιμοποιώ ένα HP windows 7 home premium. Λέτε να μην το υποστηρίζει το laptop???
Μήπως θα πρέπει να κανω κατάργηση της κάρτας και ξανά πάλι να τη συνδέσω???
Να απευθυνθώ στο support team της N/I traktor για καλυτερη εξυπηρέτηση ???
Θα ήθελα μια λύση γιατί δεν το κατέχω!!!
Φιλικά Μανώλης!!
Φιλικά Μανώλης!!
Posted Wed 04 Jul 12 @ 6:07 am
kane apegkatastasi..kai pigene sta program files na sviseis olo to fakelo tis kartas sou..eixa k egw tin idia..kai meta kane install pali..sosta omos afti tin fora!
Posted Wed 04 Jul 12 @ 6:56 am
