Awsome Scott!...man...things are picking up again..
Posted Thu 04 Oct 12 @ 9:15 pm
Awesome job Scott. Looks good, heck now you could even make that look like a mirror breaking....
Posted Fri 05 Oct 12 @ 8:05 pm
I do that every morning when I brush...he,he
Posted Sat 06 Oct 12 @ 6:17 am
Scott,
Any plans on giving use the ability to use our logo's like your "mask" transitition??
Posted Sun 07 Oct 12 @ 6:37 am
What do you mean?
Posted Mon 08 Oct 12 @ 11:52 am
Like when I move my crossfader my logo will appear and then shatter into a million pieces and the other video appears.
Posted Mon 08 Oct 12 @ 12:13 pm
Hi Scott , will be nice if u make some transition for Mac to ;-) The Shatter is a cool transition ....and your Logo slide too...
Thx Gianni
Thx Gianni
Posted Mon 26 Nov 12 @ 9:24 am
New transition available:
http://www.virtualdj.com/addons/15491/corner.html
Simple corner transition - with manually selectable corner or random mode. You can also choose whether the transition grows or wipes.
Posted Fri 14 Dec 12 @ 7:03 pm
New transition available: lumakey
http://www.virtualdj.com/addons/15608/lumakey.html
Posted Fri 18 Jan 13 @ 10:07 am
Got Em'...
Posted Tue 22 Jan 13 @ 6:16 pm
Scott, I love the Lumakey Transition effect.
Posted Tue 22 Jan 13 @ 6:46 pm
lumakey updated to v1.0.1 - fixes an issue with the "Keep Ratio" options in Virtual DJ video config.
Posted Thu 24 Jan 13 @ 1:21 pm
Shatter updated to v1.1. Major changes:
* Added adjustable rotation of shattered pieces
* Added Mac support
* Added Mac support
Posted Sat 09 Feb 13 @ 4:47 pm
Hi SBDJ, I have made a bunch of graphics to use with your Mask Transition. I am getting some screen freezing (lag) when load a new Mask. I just started using RVT, so that happens allot with most of my Masks.
Is there a preffered size of the graphic in order to make each mask Transition load more smoothly?
Thanks for all the work you put into plugins. It is really amazing all the work you have given to this community.
Posted Wed 13 Feb 13 @ 5:00 am
What image format are you using for the masks?
Posted Wed 13 Feb 13 @ 12:13 pm
Hi Scott,I was using the new video transition SHatter 1.1 last night with automix running on smart and had a problem. As tracks changed there was a stuttering as though track jammed, I was also using Sonique. this is the first time i have used shatter 1.1. problem was over come by switching video transition back to Breakthrough. I have just repeated the situation at home and get the same problem, i think i had previously used the original shatter without a problem
Posted Thu 14 Feb 13 @ 4:47 am
Interesting, I changed the render method from my own back to VDJs in v1.1. You definately had no issues with v1.0 and Sonique?
Posted Thu 14 Feb 13 @ 6:45 am
Scott,I've never had this problem before. However i cannot remember if i used the original shatter together with automix. sonique no problem.P.S. i don't have the original Shatter so can't check.
Posted Thu 14 Feb 13 @ 7:41 am
Scott ,i have just tried SHatter 1.1 with video on left deck and nothing on right deck .with crossfader on video ,crossfader and graphics jamb, track still plays, NOT ON Automix
Posted Thu 14 Feb 13 @ 7:49 am
.PNG, some are pretty high resolution. About 2000 x 2000 pixles
This one seemed to freeze a few times, for valentines day set this weekend.
Also have a Birthday party at the same show.
Posted Thu 14 Feb 13 @ 8:14 am
