Forum: Old versions
Topic: Mixtrack Pro Crossfader Problem
I'm running the trial version of VDJ Pro from VDJ LE that came included with my Mixtrack Pro on PC. It's about a week old, and the crossfader already seems to have a problem. If I bring it all the way to the left, it continues to play the music from deck 2. However, the problem does not occur vice versa, and when I bring it all the way to the right, I can no longer hear the music from deck 1.
Can anybody help me? Thanks.
Posted Sat 21 Jan 12 @ 10:05 pm
Disregard, it appears the sound settings were messed up.
Thanks anyway.
Posted Sat 21 Jan 12 @ 10:10 pm
Sorry for the triple post, but I'm experiencing this problem again. Please help.
Posted Sun 22 Jan 12 @ 3:19 pm
Posted Sun 22 Jan 12 @ 5:01 pm
Posted Sun 22 Jan 12 @ 9:53 pm
If you are using the 20 day Pro trial, also check your crossfader setting in CONFIG -> Options.
Does the crossfader actually move on-screen when you move it on the MixTrack?
Posted Mon 23 Jan 12 @ 4:48 am
Yes...no volume is coming from the headphones either.
Posted Mon 23 Jan 12 @ 7:24 am
Do have your headphones connected to the headphone socket of the MixTrack and a pair of amplified speakers connected to the master outputs on the back?
If you are trying to use your laptop's built-in sound card for master output or headphones, this won't work. LE will only work with the sound card built into the MixTrack Pro. See: http://www.virtualdj.com/wiki/VirtualDJ%20LE%20sound%20through%20computer%20speakers.html
What are your current sound settings in VirtualDJ?
Posted Mon 23 Jan 12 @ 11:46 am
Input: none...output: headphones master 1&2 heaphones 3&4 numark. Headphones are connected to jack in front of controller.
Posted Mon 23 Jan 12 @ 1:36 pm
Those settings should be correct for the MixTrack Pro.
Make sure that the CUE GAIN knob is turned up and CUE MIX is turned towards the left (CUE). Also, make sure that you have selected a deck to pre-listen to using on of the CUE buttons. Try using a different pair of headphones to rule out faulty headphones.
If none of this helps, then the MixTrack Pro may be faulty. Please contact the manufacturer Numark support for advice: http://www.numark.com
Posted Mon 23 Jan 12 @ 2:03 pm
I have done all of the following...however the controller works perfectly with serento. Would that rule out a hardware issue?
Posted Mon 23 Jan 12 @ 2:07 pm
Posted Mon 23 Jan 12 @ 2:11 pm
I've tried uninstalling but I'll follow this process and see what happens...
Posted Mon 23 Jan 12 @ 2:31 pm
The problem is still occurring.
Posted Mon 23 Jan 12 @ 2:49 pm
Your best option would be to use the live chat facility to contact support who can then remotely connect to your computer (With your permission) to look at the problem directly:
http://www.virtualdj.com/contact/index.html
Posted Tue 24 Jan 12 @ 8:10 am
Same problem here......;(
Posted Tue 12 Mar 13 @ 7:09 pm
If you have prelistening issues or the crossfader is not working as it should, apart from making sure that you have followed the instructions here.. http://www.virtualdj.com/wiki/MixTrack%20Pro.html
also check these..
1. You have connected speakers ONLY to Output 1 ..NOT 2
2. Mixtrack SOund card is set to Quadrophonic mode (4 speakers). Rightclick on the speaker icon on your (right-bottom) taskbar, choose Playback Devices. Select the Numark Sound card and choose Configure.
Posted Wed 13 Mar 13 @ 1:28 am
