djBAV wrote :
Hey Scott,
Last month you spoke of this transition that was finished and I'm just checking to see what it's called and if it will be added here.
Thanks,
B.
SBDJ wrote :
I wrote a transition that uses a picture as a mask and I belive Larry D was using it in Vegas ;)
Thanks,
B.
Posted Tue 03 Apr 12 @ 6:26 am
It'll be available soon, just trying to do a Mac version too. I've had my hands a bit full with hospital stuff the last couple of weeks.
In other news an update to ShowLogo for Mac has just been uploaded which fixes a small bug which causes your logo texture to interfere with other video plugins.
Posted Tue 03 Apr 12 @ 9:23 am
SBDJ Camera has been uploaded - a Mac only plugin for OS X 10.6 or higher.
This allows simple use of a camera source in VDJ. You can resize, reposition and modify transparency.
http://www.virtualdj.com/addons/14592/SBDJ_Camera.html
Posted Tue 03 Apr 12 @ 10:38 am
Hospital stuff! Hope all is OK :)
If the PC version is ready, then please release.
Posted Tue 03 Apr 12 @ 6:28 pm
I'm fine thanks, although I think I've picked up a bug in hospital because I appear to have come down with man flu in the last couple of hours. I spend a lot of time in hospital with my son unfortunately.
Will sort the PC version over the next day or two.
Just putting the finishing touches on a few plugins I've been working on whilst in!
Posted Tue 03 Apr 12 @ 7:31 pm
I've just uploaded another Mac plugin - SBDJ ShowCover.
Like the PC version available now this displays album art on the video output.
In this version, the ID3v2 Tag is examined for a cover first, then it falls back to the named .jpg like DJ Cels plugin uses. It also supports adjustable size and position, transparency, adjustable fade in/out and a selectable colour mask with adjustable sensitivity.
Posted Tue 03 Apr 12 @ 7:40 pm
Scott any chance of getting your show cover for PC as well?
Posted Wed 04 Apr 12 @ 2:41 am
Yes :)
Posted Wed 04 Apr 12 @ 6:41 am
Thanks mate :-)
Posted Wed 04 Apr 12 @ 7:01 am
your work is awesome sbdj please realese SBDJ Camera for windows, the new options for mac are awesome but i work in windows , thanks again for your work, and cheers from mexico :)
Posted Wed 04 Apr 12 @ 2:36 pm
At the risk of upsetting the PC users more, I've updated the Mac camera plugin to v1.1. A couple of small tweaks, and the addition of the ability to apply use an adjustable sensitivity colour mask - so you can potentially remove your background for example.
Posted Fri 06 Apr 12 @ 3:55 pm
Mac ShowCover is now available:
http://www.virtualdj.com/addons/14593/SBDJ_ShowCover.html
I'm expecting a few oddities for this one surrounding tag types and image formats so report any issues here please.
Posted Fri 06 Apr 12 @ 4:05 pm
Thank very much
Posted Wed 11 Apr 12 @ 8:37 am
ShowLogo for Mac updated to v3.11.
Simple spin feature added (with a large browser area you'll see a speed control too)
Hopefully fixed video flicker
Posted Wed 18 Apr 12 @ 6:44 am
YEAH I LIKE THIS ! !
SBDJ hit the center!
I start the test
I start the test
Posted Wed 18 Apr 12 @ 9:16 am
Transperancy worked on the camera plugin for about a day for me, now I can no longer make the webcam feed transparent. Any Ideas?
Thanks!
Thanks!
Posted Fri 20 Apr 12 @ 8:36 am
I'll have a look, it's possible I broke it in the latest update ;)
Posted Fri 20 Apr 12 @ 2:19 pm
Dear friend. showlogo install the plugin available for Mac computers and I realized that to activate the plugin, the transitions taking pictures or video cast, stop working and only remains as a switch between two channels. as an example plugin "fade transition" stop mix and melt the images is only acting as a switch.
My system is osx 10.7.3 i5 lion video card intel hd and nvidia 330m, 4GB ram.
greetings.
ps: my language is Spanish translator take care to write here.
greetings.
Posted Fri 27 Apr 12 @ 8:24 pm
I'm not having that issue here.
What version is your ShowLogo plugin?
Posted Fri 27 Apr 12 @ 10:30 pm
last version..
Posted Sat 28 Apr 12 @ 8:16 am
