Hi SBDJ, thanks for the SyphonServer8. Can you check, when i activate syphon works fine, but when i disable the syphon on vdj 8 v.1845.698 it crashes. I put on Plugins64/VideoEffects, (in Plugins/VideoEffects it doesnt show on vdj).. Thanks!
PS: My macbook is a 15 retina, GeForce GT 650M 1024 MB, 8gb ram
Mauri R.
Mauri R.
Posted Thu 26 Jun 14 @ 6:59 am
@SBDJ
Can we expect the random clip bank video plugin on 8 too?
Posted Fri 04 Jul 14 @ 11:41 pm
No - v8 doesn't have the clipbank plugin.
Posted Sat 05 Jul 14 @ 5:36 am
i see. is there any alternative mate?
Posted Sun 06 Jul 14 @ 11:24 am
v8 has a video sampler, but no random function as yet.
Posted Sun 06 Jul 14 @ 12:17 pm
http://www.virtualdj.com/addons/14198/SBDJ_BumpMap.html
Updated to v1.1
* v8 Support on PC and Mac (no support for earlier Mac versions)
* Added Wet/Dry control
* Changed beat timing engine to make it easier to understand
* Added quantize function that will snap the timing to the CBG
* Removed D3DX dependancies
Updated to v1.1
Posted Wed 16 Jul 14 @ 2:33 pm
thanks so much Scott...
Posted Wed 16 Jul 14 @ 4:08 pm
Really loved the VenueMagic plug that worked with 7 (though I wish it had a audio-link feature). Any ideas when a version 8 compatible plug will be available? VenueMagic says next month...
Posted Sat 26 Jul 14 @ 6:55 pm
Since its their plugin they would know better than me.
Posted Sat 26 Jul 14 @ 7:17 pm
No worries. I thought since you have already done one for Freestyler, they might have tapped you for some help.
Posted Mon 28 Jul 14 @ 6:48 pm
