Hi. Im using Virtual DJ 7.0.5b LE and I can't find the way to do auto crossfade between songs when they are over, so I won't need to sit at the beggining of events next to the equipment and the music will just keep play alone....
Posted Thu 22 Dec 11 @ 4:42 pm
This may be a little long....
To the right of your browser there is an adjustable window, open it a little and at the bottom left hand corner you will see a lock icon click on this to lock it (have fun trying to catch it, lol) once locked resize panel so you have enough room to fit artist and title fields.
Populate this area with your tunes you want to play, they can be either audio or video files, try and keep the bpm of each tune as close as you can this will give you a better mix.
Choose which deck you want to work off and put your first tune there or select a deck you want your playlist to follow, now when ready in the top left hand corner of the panel there are two icons, press on the top icon, this will turn green indicating automix is now working.
The second one down lists options for your mix, you also have in config > options, other selections to choose from ie length of mix etc.
If you decide you want to miss a few tunes out for some reason go down the list to where you want your next tune to come in and double click it, this will jump the playlist to that point.
You can also add to the list anytime by simply dragging your songs over from browser and dropping them in where you want.
To stop automix simply click on the green icon and you can then before the tune ends revert back to normal mixing.
hope that helps.
hope that helps.
Posted Thu 22 Dec 11 @ 6:39 pm
my cross fade not goin sliding side to side on my mixer i got numark mix deck and both songs keep playin how do i split the decks so i can hear which song i am playing
Posted Mon 27 Feb 12 @ 10:41 am
Register your Limited Edition version that came bundled with your controller to your Profile Page http://www.virtualdj.com/users/edit.html and download the latest available LE version from your Download Center http://www.virtualdj.com/download/updates.html
Then read this http://www.virtualdj.com/wiki/MixDeck.html on how to properly setup your Mixdeck controller.
Note that Mixdeck has a real analogue mixer, therefor you will not be able to see the crossfader, faders or EQ moving on the screen.
Posted Mon 27 Feb 12 @ 10:59 am
Hey,
I'm using VirtualDJ FREE home edition and I cannot find that crossfading button! Can someone help me? Thanks!
Posted Sat 11 May 13 @ 3:50 pm
I'm using the keyboard on my laptop and I have to use tab then space to play the next song is there an easier way to do this?
Posted Tue 13 Aug 13 @ 10:49 pm
If you're saying you don't know where the crossfader is, here you go.
Posted Wed 14 Aug 13 @ 9:46 am
how do i set crossfader to automatic when switching play from deck 1 to deck 2
Posted Tue 22 Sep 15 @ 6:42 am
Why would you want to do that? If you put your tunes into automix in the order you would put them on the decks then they will automatically be mixed together. But if your insistent on doing it on separate decks you could use an action points I suppose coded with 'crossfader +10%' changing the percentage amount up or down depending on how long you want it to take for the cross fader to move across + = to the right side and substitute this to - to move to the left i.e. crossfader -10%. Also you would have to set up multiple action points depending on how smooth you want the transition.
But as I said I really do not understand why you would need to do this??
Posted Tue 22 Sep 15 @ 9:52 am
Put this vdjscript on your play button (midi controller):
play_button & auto_crossfade
You can modify the length of the crossfade by writing a ms value after auto_crossfade.
Regards, Daniel
Posted Tue 22 Sep 15 @ 12:29 pm
How to auto crossfade?
Pioneer ergo & Vdj le
This question is older than stone henge and I've really searched on here and still can't see a clear & simple answer.
I'm toying with the idea of ditching the ergo controller and just using the PC and separate sound card as less to carry/ setup
Posted Sat 28 May 16 @ 8:08 pm
if you use a LE there is e.g. no automix feature avaliable
also you cannot access the mapping to create a shortcut for
a controller or keyboard button with a auto crossfade action
Posted Sun 29 May 16 @ 6:09 pm
Where can I find the midi controller file to paste this into Daniel?
Regards, Daniel
Regards, Daniel
Posted Thu 13 Oct 16 @ 5:04 am
the controllers section, or the keyboard mapping play command
Posted Thu 13 Oct 16 @ 6:34 am
How do I get my songs to start playing the next song on cue? I have my cue points but the next song isn't starting.
Posted Sat 10 Feb 18 @ 9:05 pm
Tracks don't just play themselves. You either have to press the play button (which is called "being a DJ") or use automix.
Posted Sat 10 Feb 18 @ 11:33 pm
