Thanks for the update, a while since I've posted, (SORRY) have to show you guys some love with VDJ...HAVE NO PROBLEMS with VDJ .....SOUND is AWESOME....using a DELL LAPPY,.....with 4 1tb hd's....out MON-FRI weekly.....just added MY DMX program to run lights lovin life......THX
Posted Sat 27 Aug 11 @ 8:04 am
Just wanted to say THANK YOU for such a great product!
Posted Mon 29 Aug 11 @ 1:18 pm
Do you know how much the fee is to cross over from cue to vj ? thanks in advance..
Posted Tue 30 Aug 11 @ 8:25 am
$50
Posted Tue 30 Aug 11 @ 8:43 am
Where can I find what was fix and upgrade from my version 7.02
Thanks
Thanks
Posted Wed 31 Aug 11 @ 11:44 am
http://www.virtualdj.com/wiki/VirtualDJ_History.html
Greets, Heiko
Greets, Heiko
Posted Wed 31 Aug 11 @ 11:48 am
Greets, Heiko
Greets, Heiko
Thanks Heiko,
I knew it was somewhere but I wasn't able to find it...
Posted Wed 31 Aug 11 @ 12:48 pm
wahhh !! many pr0 user .. i really d0n't kn0w h0w t0 make a s0ngs with this virtual dj h0me .. s0me1 pliz help me
Posted Wed 31 Aug 11 @ 3:31 pm
Virtual DJ is tool to mix music, not create or produce your own ones.
Greets, Heiko
Greets, Heiko
Posted Wed 31 Aug 11 @ 4:48 pm
+1
Posted Sun 04 Sep 11 @ 11:24 pm
how is this for stability at the moment, ive been busy these last few weeks so not had time to do much.. anyone got an update for me on the crash front?
Posted Mon 05 Sep 11 @ 6:23 pm
For the first time I got VDJ update installed. Hallelujah!!!!
Ok, so I installed the latest version, does it not add anything other updates in between?
Posted Fri 09 Sep 11 @ 4:50 pm
It adds everything that has changed since the last version that you used.
Please see http://www.virtualdj.com/wiki/VirtualDJ_History.html for a list of what's changed in each version.
Posted Fri 09 Sep 11 @ 5:21 pm
Exactly what does this mean? If you have a specific issue, spit it out. I have a stable machine, so have no idea what you are talking about. I am in the club now, online, downloading from beatport and other sites, on this forum, with live camera feed, and mucho effects. I don't know anything about crashes. I believe we have the same software. Let us know what your issue is, maybe there is a fix for it, or something specific to your machine.
Posted Fri 09 Sep 11 @ 11:14 pm
This version works fine until;
......at the end of the night when I try to shut the program down it puts a message up saying that VDJ is not responding. Obviously not that important as it's when I've finished using it.
It has not done this on any previous versions.
Oh, erm. PC version running on an Apple Macbook Pro Bootcamped with Windows 7.
Posted Fri 16 Sep 11 @ 4:36 am
Oh, forgot, another problem specific to this new version.
I usually use VDJ by clicking on the BPM header to sort my record case by BPM for beat mixing purposes. If I search and load a track, then clear the search field to return to the record case, the list has not stayed in BPM order, it has reverted to it's initial order as when the program was started. The is very annoying, the previous versions have never done this to my knowledge.
For these reasons I'm now returning to version 7.04 til they are fixed.
Posted Sun 18 Sep 11 @ 6:56 am
@DJSoulman, about the first issue. This is related to something specific to your computer and probably to a connected device, controller or driver. Try to find the cause of the problem by removing devices and reseting your settings.
-About the Bpm sort, i tried this here and i can't reproduce it. The sort order remain to 'bpm' after clicking in the search box to clear it or when i use my keyboard sortcuts for search and back to the list.
Latest version 7.05b.
Posted Sun 18 Sep 11 @ 8:42 am
BPM sort issue solved;
I remapped my MC6000 crossfader as I don't ever use crossfaders.
I had audio_crossfader = search_clear to clear the search box
and the video_crossfader = search to enable the cursor in the search box
By removing the search_clear from the audio crossfader the BPM sort list stays as sorted.
Found that I didn't need it anyway as moving the crossfader after a completed search clears the box anyway.
I still have no solution to the problem when shutting down the program. I installed 7.04 and it closes as expected, but, re-installing 7.05b the problem still occurs, although, not consistently at home under testing. But, after my regular 4 hour gig at my residency it always comes up with the Windows error message "VirtualDJ has stopped working".
Posted Mon 19 Sep 11 @ 8:15 am
@DJSoulman, do you have any vst's installed? I had a similar problem, I uninstalled it and everything is good now.
Just a suggestion
Huey
Just a suggestion
Huey
Posted Mon 19 Sep 11 @ 8:03 pm
No VST's installed.
Posted Tue 20 Sep 11 @ 4:03 pm
