You can find serial number and download link here: http://www.virtualdj.com/users/edit.html?view=licenses
Greets, Heiko
Greets, Heiko
Posted Fri 29 May 15 @ 5:13 am
Hi team,
I have just installed vdj to my mac,and using a dj2go too, doesnt seem to work with controller? I am not using a soundcard at moment so what configuration would i need to make it work? Thanks
Posted Tue 16 Jun 15 @ 5:30 pm
Hello I lost my license number for using dj2go.
How to retrieve it.
Thank you
How to retrieve it.
Thank you
Posted Thu 08 Jun 17 @ 8:06 pm
If you have not registered your VirtualDJ LE keycode (serial) to a virtualdj.com account in the past, we have no way to retrieve it. In this case you will need to contact with Numark Support in case they can match with a serial hardware number.
Posted Fri 09 Jun 17 @ 11:49 am
Thank you I have the purchase invoice.
Or contact technical support?
Posted Fri 09 Jun 17 @ 12:55 pm
Contact Numark Support.
Posted Mon 12 Jun 17 @ 9:59 pm
hello everyone how are you? my question today is I brought a software key from you at VDJ. I brought the key for numark but I ordered a ION brand dj2go on eBay. will the ion dj2go work on the numark dj2go key? the look identical except for the logos. any help I would love. thanks and have a nice day.
Posted Wed 27 Sep 17 @ 6:28 am
Why didn't you buy the ION DJ2Go licence?
If it doesn't work with the numark licence please contact the support. Only the are able to help you.
Posted Wed 27 Sep 17 @ 8:05 am
