Can you run any! verson of VDJ with IDJ3?
Posted Wed 15 Feb 12 @ 8:35 pm
No, only the latest legitimate purchased version of the full VirtualDJ Pro or VirtualDJ LE (Limited Edition) that was included with the IDJ3 (If it came with VirtualDJ LE) will work.
You can upgrade to the full VirtualDJ Pro at discount by going to: http://www.virtualdj.com/buy/index.html
If you like VirtualDJ, please support the software and its future development by purchasing it.
Posted Thu 16 Feb 12 @ 8:40 am
Hi, I've been having a problem with my iDJ3 the software it came with. It didn't want to work at all kept saying there was a skin error and so i download version 6 and it worked for a bit and know is saying protection 8 can you please help me and another thing do i need to buy a sound card cause the headphones don't work at all...
Posted Sat 17 Mar 12 @ 3:10 pm
You have most likely downloaded an illegal version of the software. The iDJ3 comes with VirtualDJ v7 LE. It also possible that the version you download won't work with the iDJ3 due to being too old. If you like VirtualDJ, please support the software and its future development by purchasing it at a discount: http://www.virtualdj.com/buy/index.html - Or use your legitimate LE version, which you can download again from the Download Center: http://www.virtualdj.com/download/updates.html
To resolve the skin error and/or protection error with your legitimate LE version, please contact support: http://www.virtualdj.com/contact/index.html
Once you get have done this, then please see the following page for information on how to configure the sound card correctly:
http://www.virtualdj.com/wiki/iDJ3.html
Posted Mon 19 Mar 12 @ 6:13 am
I bought mine about 3 months ago and if i play the music on my macbooks speakers, it works. but when i hook it to the cd/mp3 input on my line 6 amp, nothing plays. the output wire is a dynex rca to 3.5 mm one i got at bestbuy. Help?
Posted Wed 28 Mar 12 @ 4:06 pm
This means that you do not have it configured correctly.
Please see: http://www.virtualdj.com/wiki/iDJ3.html
Posted Wed 28 Mar 12 @ 5:22 pm
ey soo the cd that came in dosnt work
Posted Sun 08 Apr 12 @ 7:12 pm
Please register your iDJ3 VirtualDJ LE serial number on the page http://www.virtualdj.com/download/updates.html and then download the most recent version from the Download Center: http://www.virtualdj.com/download/updates.html
This can be found on the sleeve of the installation CD.
If you have lost the serial number, please see: http://www.virtualdj.com/forums/151663/General_Discussion/Lost_Serials_-_VirtualDJ_LE_or_any_other_version.html
Posted Tue 10 Apr 12 @ 6:35 am
EVERYTIME I TRY TO INSTALL THE
IDJE USB AUDIO DRIVER 2.9.11
BUY NUMARK
I GET THE
UNFORTUNATELE THE INSTALLATION FAILLED.
(Error;TIMEOUT-0X0005)
VERY UPSET DJ
I BOUGHT THE IDJ3 USB CONTROLLER
NOW AFTER 2 MONTHS
IM HAVING THE ABOVE ISSUES
THE VITURAL DJ SOFTWARE CAN'T SEE THE IDJ3 CONTROLLER?
WHO CAN HELP ME WITH THIS
PROBLEM
I HAD TO ASK ANOTHER DJ TO DO MY DOUGHTERS 17TH BIRTHDAY PARTY
VERY EMARASSING
TO ME AS A DJ NOT PLAY FOR YOUR OWN CHILDS PARTY
http://www.youtube.com/watch?v=hSz7JspwPJY
BUY NUMARK
I GET THE
VERY UPSET DJ
NOW AFTER 2 MONTHS
PROBLEM
VERY EMARASSING
Posted Wed 16 May 12 @ 11:42 am
Numark IDJ3 has no native drivers, so you dont need to install anything. Its up to windows to properly detect your device, so in case you have issues with this, please see here .. http://www.virtualdj.com/wiki/midinotdetected.html
Posted Thu 17 May 12 @ 8:43 am
I purchased and IDJ3 and I've been using it and it has been working well for a couple of months now. I wanted to buy the newest version (I have Virtual DJ LE) so i tried the 20 day demo. The 20 days expire and when i try to open my Virtual DJ LE, it says "skin error". Please help me with that if you can. Also, where is the serial number on the IDJ3 because i reset my laptop and re-installed Virtual DJ and it tells me to input my serial number which I lost. Where do I find my serial number most importantly?
Posted Sun 20 May 12 @ 8:53 am
Please perform a clean re-installation of the software. Please see: http://www.virtualdj.com/wiki/How%20do%20I%20perform%20a%20clean%20re-installation%20of%20the%20software.html
The serial number can be found on the sleeve of the installation CD for VirtualDJ LE. If you have lost this, please see: http://www.virtualdj.com/wiki/Retrieve%20installation%20file%20or%20serial%20number.html
Posted Tue 22 May 12 @ 9:21 am
can anyone help me out on my issue?? i have this problem that i bought an idj3 like last month and i have been trying to look for a software i download virtual dj and i cant use it on my controller (idj3) can anyone please help me thank you :)
Posted Wed 30 May 12 @ 10:24 pm
You should use the LE version of VirtualDJ that came with your controller. If you bought the device used and did not come with a LE software version, you can only purchase and use Pro full version http://www.virtualdj.com/buy/index.html as the other available versions (Home Free, Broadcaster, Basic) do not support midi controllers.. http://www.virtualdj.com/products/comparison.html
Posted Thu 31 May 12 @ 11:15 am
I have over 15k songs in Itunes file. How do I get my Numark Cue to recognize all the files?
Posted Fri 06 Jul 12 @ 4:58 pm
I just bought my IDJ3 yesterday. I got everything connected correctly to my mac. However, I can't hear sound thru the headphone. I also set the audio : none/ headphones/ 2 cards but it seems doesnt work still. Help please....
Posted Mon 06 Aug 12 @ 12:57 am
Goto Application->Utilities->Audio Midi Setup and see if the IDJ3 is detected as 2 sound cards with 2 ch each or a single one with 4ch.
If that is detected as a 4ch sound card, change the Config of VirtualDJ to
Inputs None / Outputs Headphones/Sound card 4out ..Numark IDJ3
If its detected as 2 sound cards, maybe you will have to create an aggregate device in order both sound cards to be used, and then have 4out- ..aggregate device in Sound setup.
Posted Tue 07 Aug 12 @ 9:01 pm
how come when i record a songs on my ipod and play them back they skip. How do i prevent this problems is there a button that i did to have on or off
Posted Thu 16 Aug 12 @ 10:02 pm
i installed my idj3 software with other softwares and now im having problems with my audio it makes weird sounds and sometimes the sound is just to ugly what can i do?
Posted Wed 19 Dec 12 @ 2:44 pm
Can you please define weird and ugly sounds ? Can you record and upload a sample or make a video with your sound issues ?
What other MIDI devices have you connected to the USB besides the IDJ3 ? Have you installed any MIDI driver software ? If yes uninstall it and try again.
Posted Thu 20 Dec 12 @ 3:13 am
