Forum: Old versions
Topic: Convert .vdj samplers to .mp3 HELP
hi, is there any way to convert the .vdj samples into mp3 format???
Posted Thu 17 Feb 11 @ 10:54 pm
.vdj samples are normally in OGG format.
You can convert them by using an audio editor such as Audacity http://audacity.sourceforge.net that supports OGG to load them and then save them as MP3. You may need to rename the file to samplename.ogg to be able to load it into the audio editor.
Posted Fri 18 Feb 11 @ 7:49 am
VickiBHome userMember since 2015
hey your app is awesome but can u please tell me in which app i can convert it audacity is not working properly
Posted Fri 10 Apr 15 @ 11:26 am
kiero cambiar formatos .vdjesample a mp3 y no puedo, como le puedo hacer
Posted Thu 30 Apr 15 @ 11:26 am
I am with the same problem, i can't convert .vdjsample files to .mp3 can somebody help us?
Posted Mon 24 Apr 17 @ 9:25 am
Did you not read the second message down?
Posted Mon 24 Apr 17 @ 9:47 am
Brenn0Home userMember since 2019
Funcionou muito obrigado !!!!
Posted Tue 14 Jan 20 @ 1:58 pm
awandzelPRO SubscriberMember since 2018
Here's how:
First understand that:
The sampler function (that records a sample and saves it as a .vdj or .vdjsample file)
and the record function which records off the soundcard and saves it as an .mp3 file..
If its a .vdjsample / .vdj then rename the file extension as .ogg.
Then run it through a standard online converter from .ogg to .mp3:
http://www.convertfiles.com/convert/audio/OGG-to-MP3.html
Posted Sun 28 Jun 20 @ 5:57 pm
I tried that, why do i get an error.
Posted Tue 23 May 23 @ 12:33 am
i ve got this problem with uploading, i tried to converted into a mp3 but is not working
Posted Sun 09 Jul 23 @ 7:49 pm
