Topic: VirtualDJ iRemote for iPhone/iPad/iPod - Page: 17
SBDJPRO Infinity Member since 2006
You have temporary use of the full product using Home Free - it allows you 10 minutes per session whereby you can use the full range of Pro features, with infinite sessions.
Posted Fri 04 May 12 @ 11:52 am
kelerikPRO InfinityMember since 2011
Arrrrrghhhh - !!!!!!!!
please read my earleir posts !!!!!!!
Can we stick to the problem in question and try not to go off on tangents that dont address the issue ?????
Please - THE HOME VERSION WORKS OK with the IPhone remote and THE PRO VERSION DOESN' T
I know all about the home version !!! Its NOT the home version that is a problem !!!!!!! - and the HOME version Surely wont ber a solution as I ve saif IF you are using it for commercial use ??????
I want to buy the PRO version ONLY if I see if working with the remote app
so can we get back to the central issue !!!
regards
Eric
Posted Fri 04 May 12 @ 12:23 pm
Eric,
Have you tried disabling your friends firewall and antivirus while using Pro?
Posted Fri 04 May 12 @ 6:44 pm
djnpdPRO InfinityMember since 2009
I am trying to run the app on a XP pro machine and an iPad, the screen on the pad is telling me "Trying to locate Virtual DJ"
HELP!!
Posted Tue 03 Jul 12 @ 3:05 am
Posted Tue 03 Jul 12 @ 3:22 am
Install Bonjour on PC, should I install the App for Bonjour on iPad?
Posted Tue 03 Jul 12 @ 4:02 am
No, just on the PC
Keith
Posted Tue 03 Jul 12 @ 4:08 am
Done that and still nothing.
Posted Tue 03 Jul 12 @ 4:15 am
jakovskiPRO InfinityModeratorMember since 2006
Click on your PCs Start menu and start a console window by typing cmd in the execute dialogue. A bacl console window should open.
Type ping an the ip address of your iphone - like ping 192.168.1.123. Yu should get some results in ms. If you get a unreachable error your Computer does not see your iPhone.
In that case it's something with your Wireless lan - maybe the devices are blocked by the router firewall ?
Greets, Heiko
Posted Tue 03 Jul 12 @ 4:36 am
sclavel wrote :
It has been reported than on iPad, sometimes the skin loads but the text are not visible.
If it happens to you, you just need to reupload a skin to the device:
To do this, connect the app and virtualdj, go in virtualdj to the iRemote page in config, and click "upload new skin".
The default iPad skin can be found here:
http://www.virtualdj.com/addons/12366/iPad_default_skin.html
This problem doesn't appear on iPhone, it has been reported only on iPad so far.
We are working to get this fixed ASAP.
yes i had this problem- but loading the default skin works well
Posted Sun 02 Sep 12 @ 1:06 am
I bought an iPhone5, it doesn't connect to virtualDJ on my laptop. Did something change? Or should it work?
Posted Wed 26 Sep 12 @ 6:57 pm
pseftPRO InfinityMember since 2009
Maybe coz the iPhone 5 just came out last week and ther isn't a app ready for it. I suggest u open up an e ticket, u mite get a quick response
Or open a new thread in the Mac discussion area
Cheers panos
Posted Wed 26 Sep 12 @ 8:45 pm
Hey guys i can't open my virtua dj l in my ipod and i paid yet so how can i get my money back
Posted Sun 28 Oct 12 @ 7:29 pm
PizZzaPRO InfinityMember since 2005
Should this app be working with iPad mini. I downloaded it and when started it stays on the TRYING TO RECONNECT.
I know the iPad is connected correctly because the MonkeyMote for Winamp works great.
Please help
Posted Sun 23 Dec 12 @ 7:20 am
Oh, and I did try turning off ZoneAlarm and that didn't help
Posted Sun 23 Dec 12 @ 7:21 am
Yes, there is no reason it should not work with the mini.
Check everything once again from the two links posted above.
Keith
Posted Sun 23 Dec 12 @ 8:00 am
To confirm. Works on my ipad mini.
Posted Sun 23 Dec 12 @ 1:02 pm
can you pre-listen/cue on the iphone app or is it just a remote controll?
Posted Sat 02 Mar 13 @ 5:44 am
DJ KozPRO InfinityMember since 2007
At the moment it is just a remote control.
Posted Sat 02 Mar 13 @ 8:18 am
92%
