Topic: on vms4 ...how to hear and use 4 decks - Page: 2
Next to the slider you should see number that coraspond to the deck for slider. Highlight the nuber to change the slider
To help you out i must give 2 solutions.
1. For non-crossfader djs. The ones that mix with volume levels and not with crossfader.
For these users.. you must set the CH-L and the CH-R crossfader ch assign (on the front of the VMS4) to OFF
This way the crossfader will work just as video crossfader.
Now map the pitchbend buttons like this.
Pitchbend -
action_deck 1 ? deck 3 leftdeck & deck 3 select & deck 3 leftvideo : deck 2 rightdeck & deck 2 select & deck 2 leftvideo
Pitchbend +
action_deck 1 ? deck 1 leftdeck & deck 1 select & deck 1 leftvideo : deck 4 rightdeck & deck 4 select & deck 4 rightvideo
Now you can use the crossfader to mix videos.
2. For crossfader djs. The ones that mix using the crossfader.
As you know VMS4 is a real analogue mixer, so you will have to manually assign the left and right crossfader_chanel assignment, using the front selectors on the VMS4. I have mapped them also and they also assign the video_crossfader chanels.
So you leave the Pitchbends as they are.
Important. Just to avoid any confusions, this is the mapper i am talking about
http://www.virtualdj.com/addons/12221/American_Audio_VMS4_Pro_Full.html
how do i add a newmark con36?
AHÍ LES DEJO MI BANDA DJ QUE TENGA EL CONTROLADOR "VMS4 O VMS4.1" EL MAPPEO COMPLETO YA LISTO PARA 4 DECKS SI NO LE LLEGAN AYAR ME CONTACTAN POR AKI Y YA LES DOY INSTRUCCIONES MAS PRECISAS, ES BIEN FACIL BATALLE PERO LO LOGRE Y LO COMPARTO CON USTEDES. SALUDOs
**LINK REMOVED**
[Moderation: Please do not post links to external mapping files. All of them are native or can be downloaded from our Download Center.]
Can somebody help me cue the music playing in my headphones through the monitor?
Yes, if you help us by giving us some more information.
