Hi Guys...I am new to using midi controller & have upgraded to VDJ 7.
I have a few questins & was hoping you will be able to help.
How do I control the 3rd or 4th with my controller & how do i listen to what I am going to play before mixing it live.
How do I also control the loop lenth without touching my laptop.
Thats all for now, any help is most appreciated.
Cheers
Graham
Cheers
Graham
Posted Mon 25 Oct 10 @ 12:59 pm
You have a lot of looks and no replies, so lets see if I can steer you in the right direction. Do you have a four player skin activated? If not, go to skins and switch. Go to sound setup, and activate for the VMS4 controller. You can also check here for a great deal of info. You can also just press a few buttons and see what happens. I don't own this controller, so can't be more specific.
Posted Mon 25 Oct 10 @ 7:47 pm
This link would be also helpfull.. http://www.virtualdj.com/forums/135723/Hardware_Technical_Support/Advanced_Mapping_Verbs_Swap_Decks.html
Posted Mon 25 Oct 10 @ 8:05 pm
