έτσι ακριβώς όπως τα λέει ο Μπάμπης είναι!!!!
Posted Mon 06 Jun 11 @ 9:23 am
grafw edw gia LE giati dn brhka antistixo topic.
Exw 2 apories, katarxas pws kanoume complete uninstal tou programmatos (na mh meinei tpt sto pc)? Ypo8etw oti oi LE exoun idia diadikasia apegkatastashs me thn pro.
Epishs, ginetai peirazontas to xml tou skin ths LE na mhn fainontai ta bpm (oxi sto search, sta decks) kai ta waveforms?
Posted Sat 11 Jun 11 @ 7:36 am
kaneis? :)
Posted Sun 12 Jun 11 @ 10:45 am
erotisi giati den exo asxolithei me to thema.
to vdj ftiaxnei kai apothikeuei playlist.
meta sto browser dixnei tis playlist pou exeis ftiaksei.
ginetai apo kei kai pera na kaneis epeksergasia ton playlist pou exeis ftiaksei?
opos na afaireseis i na prostheseis ena tragoudi....
sta grigora pou to eida de to kanei
Posted Sat 25 Jun 11 @ 5:08 pm
Aledjo me drag n drop ginetai mono sta Virtual Folders. Stis playlists, prepei na tis fortwseis (me aplo klik panw tis), na vgaleis kai na valeis oti theleis, apo to deksi meros (playlist) kai meta na kaneis save.
Episis mallon tha se volpesei to Config->Options->AutoLoad Playlists na einai sto Smart.
Posted Sat 25 Jun 11 @ 8:33 pm
Katarxin den yparxei logos na apegkatastiseis tin LE, afou opoiadipote alli version ki an valeis , px tin Home Version, den epireazei i mia tin alli (allo .exe file)
En pasei periptwsei an theleis na sviseis ta ixni tou Virtualdj, ektos apo uninstall (Windows, Control panel, prosthaferesi programmatwn), mporeis na vevaiwtheis oti kai ta registries tou software einai svismena...
Apo Start, grafeis regedit kai trexeis ton Registries Editor. Psaxnels sto HKEY_LOCAL_MACHINE->Software kai svineis to fakelo Virtualdj pou tha vreis ekei.
Gia na min fainetai to bpm sto deck, anoigeis to xml arxeio me Notepad kai psaxneis (me search) ...%Pbpmex
Otan tha to vreis..tha prepei na sviseis olo to kommati pou arxizei kai teleiwnei me <textzone> i me <button>, analoga to skin.
Logika tha vreis 2 tetoies enotites, mia gia kathe deck.
Twra gia ta waveforms, ti ennoeis, na min fainontai ta cbg, oi koukides, i olokliri i waveform?
Posted Sat 25 Jun 11 @ 8:39 pm
malista to dokimasa kai de boleuei katholou! afou akoma kai save prepei na ksanagrapseis to onoma tis playlist.
me vitrual folder ginetai kati tetoio? an nai pos?
entometaksy mou irthe mia akoma idea.
kseroume oti gia ti metakinisi enos tragoudiou mesa apo to browser tou vdj ginetai kai me drag drop
kratontas patimeno to ctrl.
omos polles fores de thelo na kano metakinisi alla antigrafi!
gi'auto leo na ftiaksoun kapoio allo koumpi opos px. ctrl+shift
gia na kanei copy to
Posted Sun 26 Jun 11 @ 3:20 am
djdad θελω να επανεγκαταστησω το προγραμμα λογω προβληματων. Οσο για τα waveforms, θελω να μη φαινεται τπτ. Ευχαριστω για τη βοηθεια!
Posted Sun 26 Jun 11 @ 3:43 pm
Anoigeis to xml, kai svineis ola ta kommatia pou arxizoun kai teleiwnoun me <rhythm> i <rhythmzone>
Vevaia kalo tha einai na kratiseis ki ena backup autou arxeiou,se periptwsi pou xreiasteis pali to skin stin original katastasi.
Posted Sun 26 Jun 11 @ 5:35 pm
akyro to brika. einai toso aplo pou niotho blakas pou rotisa
Posted Sun 26 Jun 11 @ 6:12 pm
Exω θέμα με Playlists από vdj 7, αν έχετε χρόνο δοκιμάστε το…θα είμαι σύντομος…
Θελω να κανω μια Playlists CD AUDIO,,
Το εχω ..χμ το ΕΙΧΑ κανει πολλες φορες, Ανοίγουμε το ..(π.χ) το nero>new>audio cd ,, drag and drop ένα (.m3u) test.m3u ,,,,
(Playlists σωσμένο από virtualdj 4..5)…and Burn ,…όλα…καλάαααα,,,,,
ΑΠΟ ΤΟ virtualdj 7 δε θέλει…βγάζει λαθη, με τις,(fonts)?τα(tag),το,πως με λεν,,αντε γεια ...εμεινα #@l@k!^&...............
εκτός ,αν παω στο test.m3u και κόψω με edit τα….
#VirtualDJ Playlist
#MixType=Smart
#VirtualDJ Playlist
#MixType=Smart
Posted Sat 09 Jul 11 @ 11:42 am
περι ηχου ο λογος
Παρατηρω οτι αν βαλω δυο τραγουδια μαζι να παιζουν (beatmatched) και εχω και στα δυο το bass απο το eq κοντα στη μεση (σαν να λεμε δν εχω κοψει τα μπασα απο κανενα καναλι) τοτε ακουγετε σαν να τρωει το ενα καναλι το μπασο του αλλου, ενω αλλωτε σαν να φτωχαινουν οι χαμηλες... Κανει δηλαδη το mix να ακουγεται χαλια...
Αλλο θεμα: πως γινεται να αυξηθει η ακριβεια του pitch slider; δηλαδη, στο mixtrack που τα sliders ειναι μικρης διαδρομης, για να αλλαξω ελαχιστα την ταχυτητα πρεπει να κανω παρα μα παρα πολυ μικρη κινηση στο slider. Ειναι θεμα software ή θεμα αναλυσης του slider;
Posted Tue 12 Jul 11 @ 7:05 am
XarhKos wrote :
περι ηχου ο λογος
1) auto einai fysiko. i lysi einai na peirakseis ta gain ton tragoudion i akoma kalytera na min einai kai ta 2 sliders terma. kata tin allagi na meioneis to faders tou protou kathos anebainei to deutero kai otan thes kai ta 2 mazi na paizoun, apla na einai ligo katebasmena kai ta 2
2) nai auto ginetai. posa % to exeis rythmisei? sta 6%?
simeiosi. gia na allakseis tin euaisthisia tou pitch, prepei na exeis ti pro ekdosi
Posted Tue 12 Jul 11 @ 7:36 am
δηλαδη αυτο με τον ηχο ειναι 100% δικια μου βλακεια και οχι "προβλημα" του προγραμματος να αποδωσει σωστα τον ηχο, εε; ρωταω καταρχας γιατι υπαρχουν πολλοι που υποστηριζουν οτι η ποιοτητα ηχου που δινει το vdj ειναι χαμηλωτερη απο αλλων προγραμματων (βλ. traktor). Σκεφτομαι εκμεταλλευομενος την εκπτωση της κονσολας μηπως εν τελει αγορασω το pro, εαν ομως υπαρχει θεμα με τον ηχο, με τα ιδια λεφτα -ή λιγο περισσοτερα- μπορω να παρω το αλλο προγραμμα.
Posted Tue 12 Jul 11 @ 8:22 am
ego auto ksero pou sou eipa.
episis to vdj bgazei mia xara ixo.
tora an kano lathos, as me diothosoun oi moderators
Posted Tue 12 Jul 11 @ 8:28 am
XarhKos wrote :
αυτο που περιγραφεις συμβαινει οταν τα 2 τρακς εχουν την ιδια μποτα με αντιστροφη φασης .. ειναι λογικο να συμβει με το vdj οπως και με το τρακτορ η με απλα cd...ειναι απόλυτα λογικο... λυση? κανε το ενα απ τα 2 τρακ λιγο πιο μπροστα ;)περι ηχου ο λογος
Posted Tue 12 Jul 11 @ 8:41 am
An theleis episis to pitch slider na exei ti megisti dynati akriveia (oso auto einai dynato analoga me tin alalysi pou exei to hardware), vale to pitch range stin mikroteri dynati timi dld sto +-6%
Posted Tue 12 Jul 11 @ 8:55 am
ok, σας ευχαριστω παρα πολυ για τη βοηθεια!
Posted Tue 12 Jul 11 @ 9:37 am
gamato auto to effect
http://www.virtualdj.com/addons/13389/CDJ_Frame.html
an itan kai ensomatomeno gia na mi xreiazetai kathe fora energopoihsh kai apenerrgopohsh tha itan poly kalytera
Posted Sat 16 Jul 11 @ 9:42 am
egrapse.. pali o Texzk ; (gia autous pou theloun to cd frame....)
Ostoso den mporo na min sxoliaso auto to kolima me to xaraktiristiko, ... aman kaname na ksefygoume apo ta 100'ria kai na pame se kati pou miazei perissotero me pikap.... Eseis oi veoi...
ps, den tha to katebaso. Kala eimai me ta 900aria kai to vinyl mode default (kai peiragmenon ton mapper na min mpainei kan se cd mode...)
ps2. exo kai ena kalo hack pou beltionei poly to scratch, opoios thelei, pm me.
Den to dokimasa akoma se alla players kai controllers gia auto den einai episimo.
Posted Sat 16 Jul 11 @ 12:05 pm
