Skeftomai ki egw na xtypisw ena, kai mou kanei entypwsi pws i timi tou den exei pesei katholou apo tote pou vgike. Auto vevaia mporei na einai kai kalo.. anyway. ..Sorry ligo offtopic.
Posted Tue 21 Sep 10 @ 2:25 pm
Τον συνιστώ ανεπιφύλακτα :) Και η τιμή έχει πέσει... Πριν 3 χρόνια είχε περίπου 600 ευρώ. Τώρα έχει περίπου 450.
Posted Wed 22 Sep 10 @ 12:41 pm
Vasika exw to eksis dilima...
Na parw tin Denon HC4500 kai enan tetrakanalo mikti (gia na kotsarw sto setup kai tin DP2 ..4 decks) ...dld peripou 700-750 euros i na perimenw tin MC6000 pou tha einai peripou sta idia lefta?
Posted Wed 22 Sep 10 @ 12:47 pm
Σε αυτό το δίλημμα δεν μπορώ να σε βοηθήσω... τουλάχιστον μέχρι να δω την MC6000 απο κοντά.
Αν και δεν μου αρέσουν οι λύσεις τύπου all-in-one το MC6000 με έχει δελεάσει κι εμένα.
Posted Wed 22 Sep 10 @ 12:53 pm
Pros to parwn parte mia geysi apo to kanali ths Denon sto youtube, kai krypste tis pistotikes... George kai Mpampi..
http://www.youtube.com/user/denondjtv
[EDIT]...Na po pos otan mou mpainoun tetoioi peirasmoi.. opos grafo edo edo dipla mou ta Technics 1200... tous rixno ena blemma h ta akoumpao ligo kai mou pernaei....
Posted Wed 22 Sep 10 @ 2:21 pm
apopsis 8es na sou daneisw ta cdx na xelapikareis ligo??? :P
Posted Thu 23 Sep 10 @ 4:09 am
Afou exo ta original leme...
omos sou brika antallaktika vinylia klp gia ta cdx, just in case..
http://www.soundservice.gr/e-shop/product.php?products_id=1487
http://www.soundservice.gr/e-shop/product.php?products_id=1539
http://www.soundservice.gr/e-shop/product.php?products_id=1540
Posted Thu 23 Sep 10 @ 4:59 am
kai gw exw ta original:P:P
btw ta xw mpanisei auta...psaxnw omws ftina egxrwma vinylia wste na ta balw sto cdx...exei kaneis tpt spare?
Posted Thu 23 Sep 10 @ 7:08 am
Diladi kaneis trypes se opoiodipote vinylio 12" kai to bidoneis epano ?
btw. Ta Denon 3700 exoun plato 9".. oute 7 oute 12...
Posted Thu 23 Sep 10 @ 8:12 am
akrivws auto!
malista sou dinei kai patron gia na mi kaneis la8os..allwste kai tis numark einai kanonikotato vinilio
Posted Fri 24 Sep 10 @ 4:29 am
Posted Sat 25 Sep 10 @ 10:00 am
Γεια σας
Χρει'αζομαι τα φώτα σας.
αποφάσισα να μαζεψω (για Mobile dj) 2 cdj 350 ένα απλο μικτη τρικάναλο με usb(δεν σκοπεύω να παρω pioneer επειδη ειναι πολύ ακριβοί) ηθελα ομως πρώτα να σιγουρευτώ άν τα παραπάνω μπορούν να κοτρολαρουν το vdj και αν ναι με ποιο τρόπο?
δλδ πως θα πρεπει να συνδεθουν ετσι ώστε να παιζουν cd και ταυτοχρονα kcontroller? και επισης αν χρειαζεται καποιος ειδικός μικτης?
αυτά thanks!
αυτά thanks!
Posted Fri 11 Mar 11 @ 5:49 am
Τα CDJ-350 μπορούν να ελέγξουν το VDJ χωρίς κανένα πρόβλημα. Το μόνο "πρόβλημα" που θα έχεις είναι οτι αν αποφασίσεις να τα χρησιμοποιήσεις ΚΑΙ σαν κάρτα ήχου (δηλαδή ο ήχος του VDJ να βγαίνει απο τα Pioneer) τότε όσο τα Pioneer θα παίζουν CD ή USB Stick το VDJ δεν θα μπορεί να παίξει ήχο.
Για μένα η "καλύτερη" λύση αφού πας σε CDJ-350 είναι να πάρεις και μία κάρτα ήχου όπως η Audio2Dj http://www.djshop.gr/displayITM2.asp?ITMID=13214&LANG=GR (αλλά φρόντισε όμως να κατεβάσεις τους παλιούς drivers μιας και οι καινούργιοι έχουν κάποια προβληματάκια) και να βάλεις το VDJ να παίζει απο εκεί, ενώ τα Pioneer θα δουλεύουν ως απλός controller στο VDJ.
Επίσης σε μια τέτοια λύση καλό θα είναι να πάρεις ένα τετρακάναλο μίκτη όπως ο Vestax VMC-00a4 XLu http://www.djshop.gr/displayITM2.asp?ITMID=11854&LANG=GR για να συνδέσει τα πάντα πάνω χωρίς transform switches
Τέλος θα χρειαστείς και την πλήρη έκδοση του VDJ Full PRO απο εδώ: http://www.virtualdj.com/buy/index.html
Edit: Τα CDJ για να δουλέψουν ως controller απλά τα συνδέεις με το USB καλώδιο στον Η/Υ σου και εγκαθιστάς και τους ASIO drivers της Pioneer
Posted Fri 11 Mar 11 @ 6:17 am
Ευχαριστώ για την αμεση και αναυτική απαντηση Phantom.
Κατι ακόμα λές να χηρσιμοποιήσω εξωτερική καρτα ήχου.
Ερωτηση: οταν επιλεξω ενα μικτη που (οπως λενε στα manual) συνδεοντας τον στο Laptopi τον"βλέπει¨σαν καρτα ήχου, δεν θα μου κάνει δουλεια΄? θα χρειαστεί να παρώ παλι καρτα εξωτερικη?
και επισης ακτι ακομα'
για να γινουν τα cdj kontroller απλα συνδέουμε τα usb tou στα usb του λαπτοπ και τέλος?
αυτά
συγνώμη για τις αφελείς ερωτήσεις αλλα οσο και αν εψαξα δεν μπορεσα να σιγουρευτώ για αυτα
αυτά
Posted Fri 11 Mar 11 @ 6:26 am
Ksexna ta 350 an theleis na doulepseis kai cd kai controller. Ta 350 aposyndeoun tin karta hxou tous apo to pc kathe fora pou allazeis se cd kai crasaroun to opoiodipote programma ta xrisimopoiei eite einai to traktor eite to vdj. Auto einai kai episimi paradoxi tis Pioneer kai to syzitisame kai edo. To idio kanoun kai ta 850.
Gia ybridika controller/cd player des kai tin seira Radious tis American Audio. Den ta exo dokimasei alla ypostirizontai ammesa apo to virtualdj kai toulaxiston me auta den tha klais ta lefta sou kai tha sou meinoun xrimata na agoraseis to virtualdj PRO giati autin xreiazesai gia na syndeseis eksoterikous controllers kai mikti. Kai to tonizo auto giati auta einai advanced setup, kai otan tha xreiasteis epipleon bohtheia na ta setareis exei simasia na eimaste edo kai auto tha ginei mono an exeis tin pro -registered-.
[edit] molis twra eida oti sou apantise kai o Phantomdj, alla leme peripou ta idia pragmata.
Posted Fri 11 Mar 11 @ 6:29 am
Θα πρέπει ο μίκτης να φαίνεται σαν ΤΕΤΡΑΚΑΝΑΛΗ κάρτα ήχου (δηλαδή 2 stereo κανάλια) κάτι που απ' όσο ξέρω δεν υπάρχει στους low/mid-entry level μίκτες αλλά μόνο σε πιο ακριβά μοντέλα. Οπότε μάλλον ναι θα χρειαστείς και εξωτερική κάρτα ήχου
Posted Fri 11 Mar 11 @ 6:44 am
phantom καλημερες,δεν αναφερομαι μονο σε εσενα αλλα λογο του οτι παλαιοτερα με ειχες βοηθησει αρκετα μια ερωτηση που αν μπορεις απαντας,
.....θελω να προχωρησω σε αγορα των numark ndx 800 και να τα δουλευω ως controler η κ σαν κανονικα cd στην δουλεια μου
θα ηθελα την αποψη σου οταν βρεις χρονο
εψαξα κ βρηκα κ τους mapers απο το site μας απλα θα ηθελα να ηξερα αν κα κατα ποσο καλα ανταπορινοντε σωστα στη δουλεια η αν εχουν παρουσιασει κατι που μπορει να μην γνωριζουμε πχ κολληματα οταν θες απο controler να το αλλαξεις με το κουμπι σε cd...κτλ
ευχαριστω..
ευχαριστω..
Posted Sat 04 Jun 11 @ 3:13 am
Δεν το γνωρίζω... Προσωπικά δεν είμαι οπαδός της Numark αλλά αυτό είναι καθαρά προσωπική επιλογή και σε καμία περίπτωση δεν αποτελεί συμβουλή και προς τρίτους!
Posted Mon 06 Jun 11 @ 5:24 am
geia sas guys..Anarwtiomoun an yparxei kapoio controler gia na elegxei mono ta filtra kia to echo k ta ypoloipa effe tou virtual..douleuw me timecode me allo program vevaia alla skeftomai na paw sto virtual gt m aresei to interface tou..tes pa..den me endiaferei opws katalavate ta play pause k ta sxetika..an yparxei enas controler mono gia ta effe k an einai dynaton gi to ka8e kanali diaforetika..euxaristw ek twn proterwn paidia
Posted Tue 20 Sep 11 @ 3:43 pm
To VirtualDJ sou epitrepei na mappareis mia konsola opws esy theleis. Epomenws auto pou psaxneis einai apla mia mikri konsola me arketa knobs.
http://www.akaipro.com/lpd8
http://www.korg.com/nanoseries2
http://www.zomo.de/en/Products/MIDI-Controller/Zomo-Midi-Controller-MC-1000.html
Posted Tue 20 Sep 11 @ 7:38 pm
