Forum: Old versions
Topic: DISCOVER DJ USB DJ controller - Page: 3
I've got this code
F0 7E 00 06 02 00 01 3F 11 00 19 00 01 00 00 00 7F 7F 7F 7F 00 4E 03 01 00 00 07 49 01 02 03 08 09 06 08 04 F7
90 4D 7F 00
B0 19 01 00
B0 19 01 00
B0 19 01 00
B0 19 01 00
80 4D 00 00
PLEASE Help!
Posted Tue 01 Feb 11 @ 7:13 pm
Posted Wed 02 Feb 11 @ 5:15 am
@ Support...it appears that whilst the ION Discover is natively supported in VDJ, the sysexid's seem to differ across units - this is also true of the Mixmeister controller, as I have found with the Numark Mixmeister controller mapping I created.
One advantage of having the device files available, is that people can run MIDITRACE and alter the sysexid, but alas, when a device is natively supported, there is no access to the device files - unless I've missed something.
I'd be interested to talk to someone from Numark (I believe there is an association between Numark and ION) regarding the assignment of sysexid's to the units they ship
Posted Wed 02 Feb 11 @ 5:31 am
It is possible to account for this by including ?? in the appropriate places in the sysex ID. Normally the last 4 bytes before the F7 will contain the version number and may change from one unit to another due to different firmware.
The definition for the Discover DJ already takes this into account and should work with the ID posted above.
Posted Wed 02 Feb 11 @ 6:46 am
@ support...could you give examples of wildcarding the sysexid...as this would make the mapping I created a little less problematic to setup for those that are unsure of altering XML files.
Simon
Posted Thu 03 Feb 11 @ 5:05 am
Using the example posted above, you might use:
sysexid="F07E??060200013F11001900010000007F7F7F7F004E03010000074901020308????????F7 "
Replace bytes that are known to change from one firmware to another with ?? - Usually this is the last 4 bytes (8 hexadecimal digits), but this is not always the case for all controllers.
Posted Thu 03 Feb 11 @ 12:55 pm
@Simon Bailey could I get the Mixmeister mapping that you have done for Virtual DJ. I have been wanting some help with figuring them out. Many thanks in advance. deevaughnjay at ***@****
[Sorry, E-mail addresses and other contact details are not permitted for unlicensed users. Also, mappers are only available from http://www.virtualdj.com/addons/controllers.html for registered licensed users who have purchase VirtualDJ Professional http://www.virtualdj.com/buy/index.html - We do not permit 3rd party sharing on this site.]
Posted Tue 05 Apr 11 @ 6:07 pm
Just bought a license for my Discover Dj and it still wont connect. I dont know how to connect it.
Posted Tue 17 Jun 14 @ 12:58 am
You will need to login with the Username (login) and password on the pop-up Login window that will appear on launch in order to unlock the specific controller.
You should then be able to see the name of the device in the Licenses tab of Config (inside the Current licenses box), and the controller properly detected in the Config->Controllers tab.
Please also make sure the "factory default" is selected from the Mappings list for the controller.
Posted Tue 17 Jun 14 @ 11:36 am
