Forum: Greek Forum
Topic: Hercules dj console rmx headphones help
lazikHome userMember since 2007
Lipon exo pro vdj 5.2.1 kai skin tis hercules ola ta drivers stin hercules full telospanton kai exo problima pos mporo na balo ta akoustika kai otan akougete sto ena deck apo ta ixia na akouo to allo deck apo ta akoustika... basika ta ixia pou dokimazo eine sindedemena sto pc kai otan kataferno ta akoustika na douleboun apo to hercules den akougete eixos apo ta ixia katholou.... kai sto config exo inputs none outpouts headphones sound cards 2 kartes proti tou pc mou deuteri tou hercules... outpout channels master first card/headphones second card kai ta akoustika apla den akougonte katholou.... kai ama allakso ta output channels kai balo master second card/headphones first card apla den kanei tpt to master stin konsola kai mporo na xamilono ton ixo mono apo vol deck a /deck b kai ta akoustika pali no sound opou kai na ta sindeso... kai den exoun problima ta akoustika oute h konsola exo dokimasi pola akoustika kai stin consola eipa oti ama balo apla outputs headphones kai sound card tis hercules mono akougote alla den akougete tipota apo ta ixia ... perimeno apantisis:P
Posted Sat 25 Apr 09 @ 11:45 am
Καλησπέρα,
έχω ακριβώς το ίδιο πρόβλημα και δεν βρήκα λύση ακόμη. Έχω στείλει και ticket στην Atomix Και ακόμη περιμένω...
Posted Sun 10 May 09 @ 11:36 am
Katarxin den exw tin RMX, alla epeidi moiazei me tin palia Hercules stis sundeseis, ekana kai ena mikro search kai parathetw ta akoloutha.
Sundeoume ta ixeia sta outputs 1 kai 2 tis RMX (RCA i jack, den exei simasia) . Ta akoustika panw stin konsola stin antistoixi eisodo (jack).
Twra prepei na apofasisoume an tha xrisimopoieisoume ASIO i WDM drivers. An syndesete CDieres i pikap tote prepei na balete ASIO drivers, an oxi, douleuei mia xara kai me tous dyo.
Gia na epileksoume ASIO i WDM drivers prepei na anoiksete to Remix Control PAnel tis RMX kartas. Den kserw pws akrivws anoigei, fantazomai tha sas exei vgalei kapoio eikonidio katw deksia.
Rythmiseis VirtualDJ
Pate sto config...Sound setup kai epilegete...
Gia WDM DMode
Input ... None
Output...Headphones
Sound Card ... 4.1 Card
Sound Card(s) ... Hercules Dj Console RMX
Output chanel... Master..Front/Headphones..Read
Gia ASIO Mode
Input .. None
Output .. Headphones
Sound Card ... ASIO
SOund Card(s) Hercules ASIO Rmx
Output chanel ... to idio opws panw.
Meta pate sto PErformance
Latency sto auto
Safe Mode and Overclock Unchecked
Scratch to Optimise for Latency
Check Enhanced Algorithm and Filter Smooth
Low Pass Filter should be checked
Filter Smooth unchecked
An xrisimopoisete ASIO tote kante tin rythmisi "AISO mode at 44100Hz sample rate,16-bit Sample Size and 960 (21 ms) Buffer Size." pou tha tin breite sto control panel tis RMX.
Rikste kai mia matia edw, yparxoun kai eikones http://www.virtualdj.com/wiki/Hercules%20RMX%20Setup.html
Elpizw na sas boithisa.
PS. Oi parapanw rythmiseis gia to VirtualDJ proypothetei tin Pro Ekdosi 5.xx kai oxi tin Limited.
Posted Sun 10 May 09 @ 7:41 pm
