Hey guys,
i got Virtual DJ Pro and the Hercules RMX console..
in the past i used virtual dj pro on windows xp. the loops i made worked 100 percently! PERFECT!
but now i changed to mac. i am still using the hercules rmx console on virtual dj pro.
coming to my problem now.. when i wanna do loops e.g. 4, then it is not really 4 instead it is something like 3,8.
it is not really even. on windows it was even. i don't know what's wrong. the BPM is correct and all the other things are working.
do you guys understand what i mean?
if not, i will try to explain again. thanks for your support guys!
Posted Sat 22 Nov 08 @ 9:19 am
Hello newlightpictures,
If you have VirtualDJ Pro, you have a "Smart Loop" setting in the loop area of VirtualDJ Pro internal mixer skin: can you check if, when you activate the Smart Loop mode, you still have this issue?
Posted Sat 22 Nov 08 @ 11:33 am
Hello.
Sorry for answering so late.
Yes I tried both. I had the "Smart" Option turned on and off.
I still have the same issue.
What now?
What now?
Posted Mon 24 Nov 08 @ 7:45 pm
Hi Newlightpictures, Pls register ur Pro serial at ur modify ur profile n update to recent v5.2.1 Pro. Thanks n welcome;)
Posted Mon 24 Nov 08 @ 8:28 pm
ich habe das gleiche Problem, selbst wenn ich den song stoppe, ganz genau die loop-markierungen setze, gibt es immer einen unsauberen loop bzw. der song läuft immer asyncroner zum anderen Deck :(
Posted Fri 23 Jan 09 @ 1:10 pm
Hi skippy, r u having the same problem??
Pls do speak english here or u can also post it in the german forum.
https://virtualdj.com/forums/6/German_Forum.html
Regards;)
Regards;)
Posted Fri 23 Jan 09 @ 2:46 pm
sorry i mean the loop in and loop out doesn't match perfectly, there are always gaps in the loops and it looses syncronisation to the other deck....I do have to press the intellligent loop button two times before it fits perfectly...can you please help me with this problem?
Posted Sat 24 Jan 09 @ 6:14 am
Yeah I'm having the same problem (but on the PC as well, with 5.2, tried it out at a friends).
Is this "feature" fixed in the 5.2.1 update?
Posted Tue 03 Feb 09 @ 4:41 am
Hi fsfreak, pls register ur serial and grab the recent updates. thanks;)
Posted Tue 03 Feb 09 @ 6:18 am
is the problem fixed now?! I still have the same problem with the loops!!!
Posted Wed 27 May 09 @ 6:09 am
it's now fixed finally!!! even in the beta version of vdj 6!!!! =)
THANK GOD!
THANK GOD!
Posted Fri 05 Jun 09 @ 12:47 pm
