Hi I have a problem with my Virtual Vinyl system..
I Just bought it some weeks ago.. I have used it 1 Time, and the next time I wanted to play records with Virtual Vinyl it was saying
Timecode Quality : 0%
I haven't removed or changed any cables, and I have checked if they were loose.!
No matter what I do, I cant get Timecode Quality to 100% again..
I have tried to Reinstall Windows / Reinstall the drivers / Installing on other Computers / switching cables.. Nothing works!..
My specs are :
2x Pioneer CDJ1000MK3 (using cd's)
1x Pioneer DJM800 Mixer
Virtual Vinyl system with the USB interface.
Have tested on computers :
Desktop : 3ghz , 2gig Ram running Windows XP pro, with all updates installed..
Laptop : 2.4ghz, 1gig Ram running Windows Vista 32bit, with all updates installed..
Can anyone please help me!..
Thanks!
My specs are :
Thanks!
Posted Wed 12 Nov 08 @ 11:58 am
Hello,
stop virtual vinyl, disconnects and connects the interface, starts virtual vinyl.
This works for me...
https://virtualdj.com/forums/98289/PC_Version_Technical_Support/Timecode_Issue.html
Posted Wed 12 Nov 08 @ 12:46 pm
It worked on one of the sides.. (left)
But when i installed the New software and tried again, I couldn't get anything again..
no matter which order I turn on my equipment
Posted Thu 13 Nov 08 @ 10:01 am
Here is a video of my setup..
http://www.youtube.com/watch?v=BWKSGy8GvQA
Posted Thu 13 Nov 08 @ 12:23 pm
Alright. I got it to work.. but only with the old version of the program.. I still want the new version to work as well as the old one!
Posted Thu 13 Nov 08 @ 1:28 pm
Rune2410, I haven't got, Virtual Vinyl, but in the latest version you have 5.2.1 (I guess). In the timecode config, do you have a option on what timecode engine you want to use.
In VirtualDJ you have a choice of the old v4 engine, the new v5 engine, or the noisemap engine (n/a with Numark Vinyl's + CD's). If you have this option in VV have you tried the different engines.
Posted Thu 13 Nov 08 @ 1:40 pm
This message is to Jimmyb
ineed help please
ineed help please
Posted Thu 13 Nov 08 @ 3:00 pm
ineed help please
I NEEDDDDDDDDDDDD HELPPPPPPPPPPPPPPPPPPP
ineed help please
Posted Thu 13 Nov 08 @ 3:03 pm
With WHAT
Posted Thu 13 Nov 08 @ 3:17 pm
discobrian24 wrote :
With WHAT
yeah with what, cheer's brian, lol
Posted Thu 13 Nov 08 @ 6:36 pm
Alright.. Now i'm back to square one!..
none of the versions works now.. and happened same way as last time, it just stopped working..
Its really driving me crazy that I can't play with my virtual vinyl when i bought them!..
Someone MUST have a solution to get it to work !!
Posted Fri 14 Nov 08 @ 4:18 pm
Try the v4 timecode engine.
V5 timecode engine is not "better" then v4, it's just an alternative, might v4 not work. I've found v4 to work more often then v5. :)
Posted Sat 15 Nov 08 @ 4:08 am
I currently have the CD version installed. so that automatically used the V4 engine doesn't it ??
Posted Sat 15 Nov 08 @ 8:01 am
hello
I think that it is a problem of manufacture, far too much present interface this problem.
Moreover numark did not answer the questions that I sent to them.
I am really disappointed of numark.
DJnicod
DJnicod
Posted Sat 15 Nov 08 @ 11:03 am
I Am too.
I have used it only Once, and then it started being weird.. thats not good service
Posted Sat 15 Nov 08 @ 11:54 am
