I have two virtual vinyl timecodes and the hercules dj console rmx and I cannt get the timecodes to work i set up for the timecodes under the options but i cant get any sound to play through the turntables. Can anyone help?
Posted Thu 23 Oct 08 @ 9:19 pm
can i call u too? i need some help...
Posted Wed 29 Oct 08 @ 9:31 am
I was under the impression you have to have a version of Virtual Dj Pro to use timecodes
Posted Wed 29 Oct 08 @ 9:34 pm
i do have pro, i have the 5.2
Posted Thu 30 Oct 08 @ 10:24 am
Register it in your profile by entering your serial number, to gain
the full access of pro version benefits.
Posted Thu 30 Oct 08 @ 1:09 pm
This is the first step you have to do
https://virtualdj.com/homepage/xonor/blogs/3289/Modo_ASIO_para_todas_las_Hercules_RMX_y_MK2.html
Config the ASIO mode, and now you can use TCVs by sellecting in "inputs" your correct timecodes.
Posted Thu 30 Oct 08 @ 8:35 pm
thanks man!
Posted Mon 10 Nov 08 @ 3:14 pm
Hi again.
VDJ 5.2 it's not the pro version.
5,2 comes with the RMX, and it's a limited edition.
When you have pro version, you can do many more things than limited, and have full access to downloads.
If you have the pro version, please register your serial# in "modify my profile".
Anyway, with the limited edition, you can use timecodes but only for a few minutes.
With pro version there is no limit.
Posted Mon 10 Nov 08 @ 6:31 pm
