Hi guys,
I'm using Leopard on my mac, and everytime I open VDJ I lose all my bpms. I've set all vdj related files to "Read & Write", but I still keep losing the track's bpms. Does anyone know what am I doing wrong?
Posted Wed 08 Oct 08 @ 7:07 pm
Hi pioneerdigi, are u sure u have set the vdj folder to read n write?
Just double checked go to finder and to ur application and at vdj, click to get info and there u set to read and write.
What is hdd format as? On internal or external did u access on?
Regards;)
Regards;)
Posted Wed 08 Oct 08 @ 11:10 pm
also check your itunes folders and make sure they are read and write also plus make sure it is 'everyone' not just 'user' that you are setting to read/write
Posted Thu 09 Oct 08 @ 2:11 am
its an external hard drive, also set to read/write...
Posted Thu 09 Oct 08 @ 3:28 pm
Hmm... I think reinstalling might be a good option.
Read this recent thread on bpm issue too but this is on tiger but followed some of the ordeal, it might help.
https://virtualdj.com/forums/97350/MAC_Version_Technical_Support/How_to_get_the_bpm_s_saved__SOLVED_.html
Post here ur result n i try to think of something;)
Posted Thu 09 Oct 08 @ 3:36 pm
you mean reinstalling vdj?
Posted Thu 09 Oct 08 @ 3:44 pm
Yes. It could help. I dun really understand why urs won't save:(
Also btw what format the external hdd? Fats32 etc.....
Posted Thu 09 Oct 08 @ 3:45 pm
apparently problem solved. Bpms being saved, only one track doesn't, but I coan live with it :)
everything else, so far so good. let me see how it goes.
thanks
thanks
Posted Thu 09 Oct 08 @ 4:29 pm
Nice to hear its working for u;) The one track that won't save its bpm... what file types are they?
Posted Thu 09 Oct 08 @ 4:35 pm
mp3, same as the others. quite a riddle... lets see if its working properly, I have a gig tomorrow, gonna give it a try. thanks anymay
Posted Thu 09 Oct 08 @ 9:48 pm
Ok all the best;)
Posted Fri 10 Oct 08 @ 12:04 am
I have an american audio vms4.1 and i have a serious problem. Everytime i put a song to listen to it on my headphones, when i press the cue button vdj synchronizes
both of the songs .. can you please tell me how to fix this cause i have to work the day after tomorrow?
Posted Tue 17 Jun 14 @ 5:54 am
