Forum: Old versions
Topic: PROBLEM: i have a problem opening up VDJ!
When i start up virtual dj a pop up comes up: Skin, so i shose my skin then click ok, it then says "virtualdj will now try to connect to the internet and check if a new version is available. you can disable this behaviour in the config menu at any time" i then click ok, then a nother pop up pops up saying the intenal database is corrupted.
then it says please contact /http/virtualdj.com/contact/
what do i doo,,,,,,i am so desprate to use this program
Posted Mon 29 Sep 08 @ 9:32 pm
Please do not double post.
