When i start up virtual dj a pop up comes up: Skin, so i shose my skin then click ok, it then says "virtualdj will now try to connect to the internet and check if a new version is available. you can disable this behaviour in the config menu at any time" i then click ok, then a nother pop up pops up saying the intenal database is corrupted.
then it says please contact /http/virtualdj.com/contact/
what do i doo,,,,,,i am so desprate to use this program
Posted Mon 29 Sep 08 @ 9:29 pm
What version are you using?
Posted Mon 29 Sep 08 @ 9:32 pm
Version: 4.1
Posted Mon 29 Sep 08 @ 9:33 pm
sorry i double posted...
Posted Mon 29 Sep 08 @ 9:39 pm
I would delete the version you have, and download the newest trial version...I bet then you could use the program..for 20 days...
Posted Mon 29 Sep 08 @ 9:47 pm
why only 20 days. "trial ver." when i have full ver. Im not deleting it sorry.
Posted Mon 29 Sep 08 @ 9:51 pm
please reply: what do i doo
Posted Tue 30 Sep 08 @ 12:17 am
If you purchased the software, please register it.
If you downloaded the software from limewire or bit torrent, Then I'm afraid that you'll find that VDJ does not offer tech support for cracked or illegal versions.
Posted Tue 30 Sep 08 @ 1:06 am
nooooooooooo my mate bought it for me for my b-day new in a package
Posted Tue 30 Sep 08 @ 1:13 am
You still need to register the software to prove it is a
legitimate version.
legitimate version.
Posted Tue 30 Sep 08 @ 11:49 am
