Have bought from DMXsoft.com the Sunlite DMX-USB, since I read through the vdj forum and understood this is supportd by VDJ.
However under VDJ 5.2.1 pro it does not work. I have model Sunlite Siudi 6c V1.14 firmware. And installed the window XP driver. When i start Sunlite Easy Stand Alone version march 2008, the following leds shown on the DMX-USB box. orange light on means power by USB, red led flickers mean DMX works, green starts to flicker as soon as you start easy stand alone, e.g. there is communication between the dmx software and the usb box. When I start and enabble DMX in VDJ (easy stand alone is not active) the green light stays off. So it does not work. Do i need to install an other driver or ........??
freek
freek
Posted Fri 26 Sep 08 @ 2:21 am
