Hiya iv got the Demo of Vdj. 2 see if i like it b4 i buy the software but i want to use it with my DN-HC4500.can any one tell me how to set it up. thanx for your time Dave
Posted Wed 17 Sep 08 @ 9:20 am
Dave,
The DN-HC-4500 has native controller support now in VirtualDJ,
Download the latest Demo (VirtualDJ 5.2, I think) and give it a try. As for the set up I can't really say, as I don't have that controller.
Posted Wed 17 Sep 08 @ 10:30 am
I have the controller. Check out this video I made recently http://www.youtube.com/watch?v=vy0Wm2vcdF4
...I could probably help you out if you want.
What kind of problems are you experiencing ? Did you already registered your HC4500 with Denon ? What operating system are you using ?
I will strongly recommend buying the VDJ software so you can have full access to the mapper, skin, etc. It's well worth it.
Send me a PM, perhaps you could skype me so I can walk you through the setup process, or if you prefer I could probably put a video together for you and the rest of the users.
Saludos,
DJ LOBBO
Posted Wed 17 Sep 08 @ 10:44 am
Install the JPBoggis custom mapper as an add-on once you are a licenced user. It will blow you away.
The VDJ with the DN-HC4500 really pushes boundaries. It's amazing.
Posted Wed 17 Sep 08 @ 12:47 pm
Make sure you update the Denon HC4500 to the latest firmware from Denon, otherwise the controller may stop responding after a few minutes:
http://www.denondj.com/plugin.asp?prod=DN-HC4500
Posted Wed 17 Sep 08 @ 4:54 pm
