BROWSER ON
pannel id="7" group="4" visible="yes">
size width="993" height="300"/>
pos x="17" y="452"/>
/pannel>
browser pannel="7">
size width="955" height="299"/>
pos x="52" y="452"/>
text font="Verdana" size="14" color="#C8C8C8" selected="#0000FF"/>
options font="Tahoma" size="13" color="#C8C8C8" over="#0000FF"/>
widgets font="Virtual DJ" size="10" color="#C8C8C8"
facecolor="transparent"
lightcolor="#0000FF"
shadowcolor="#0000FF"
darkshadowcolor="transparent"
highlightcolor="transparent"
trackcolor1="transparent"
trackcolor2="transparent"/>
/browser>
BROWSER OFF
pannel id="8" group="4" visible="no">
size width="950" height="300"/>
pos x="53" y="452"/>
down x="20" y="2005"/>
/pannel>
Can someone tell me if there is a mistake in this code. I had to remove the first symbol of each line. there is no problem inside the markup browser. my question focuses on pannels !!
Because i have something strange with the pannel of the browser as if it was a shadow when i use pannel 7. (i use the move of the mouse on pannel 7 to show parts of the browser)
The down of pannel 8 is a new pannel which switches with the browser
BROWSER ON
/pannel>
browser pannel="7">
/browser>
BROWSER OFF
/pannel>
Posted Thu 20 Jan 05 @ 7:32 pm
Hmm. Doesn't look like theres anything wrong there. Whats happening when you run the skin in VDJ? You said it was shadowing ?
Clint.
Clint.
Posted Thu 20 Jan 05 @ 11:44 pm
* First i have no xml error found by VDJ
* Yes when i do [show_pannel(7)] the browser is active but hidden behind the main skin. So when the mouse go on the pannel 7, the browser begins to appear little by little.
* Same issue if i use the same value for pos and size in the 3 case
Posted Thu 20 Jan 05 @ 11:59 pm
Hi , i'm italian excuse me if there's grammatical errors...
your problem is when select the pannel 8 vdj show some parts of pannel 7?
If yes... ...use all parameter pos, up and down.( up and down use equal value).
Posted Fri 21 Jan 05 @ 1:46 pm
no prob with pannel 8 only with the browser on pannel 7. And sorry too for my English. I'm French ;-)
Posted Fri 21 Jan 05 @ 3:18 pm
