why when I do a search I have a lots of BAD results ? ...for example : songs that I have in a hard disk not connected (H) - in previous versions , when you turn off a external hard disk you can't find the songs located on it .
Posted Fri 05 Sep 08 @ 9:59 am
Connect the Harddrive you dont want to have part of search, right click that drive inside virtual DJ (or the folders with music), and select "remove from search database"
when you want to use the drive again, do the oposite... "add to search database"
both operations takes a second or two...
Posted Fri 05 Sep 08 @ 10:12 am
yes , but I remember other previous vdj version .... when you turn off an usb harddisk it disapear from database , without to do nothing extra .
Posted Fri 05 Sep 08 @ 10:22 am
