Is the VirtualDJ Home edition no longer available? The download link goes to the Pro version only.
Also can the M-Audio Xsession pro (MIDI Mixer) work with the Home edition of VirtualDJ?
Thanks for your time!
Posted Fri 29 Aug 08 @ 8:21 pm
If you need to redownload your copy of HomeEdition, you need to enter your serial number in your profile.
And no, in order to use any external device or mixer, you need the Pro version.
That's the main limitation of the HomeEdition: you need to move the crossfader with your mouse. If you want to use a real fader, you need to buy the Pro version.
Btw, if you enter your homeedition serial in your profile, you'll be able to buy the Pro version at a cheaper price ;)
Posted Sat 30 Aug 08 @ 4:52 am
I don't have the software yet, that's why i was asking. I was looking at maybe purchasing the Home Edition if it allowed mapping my mixer, and worked with my indigo DJ. But it sounds like i would need the pro version for that. Can't spend $300 right now, so i guess i'll pass for now.
I just though it was odd that there isn't a demo for the Home version i could download.
But thanks for the info.
Posted Sat 30 Aug 08 @ 11:49 am
Its defo worth saving up for the pro version :)
Will allow you to take advantage of all features, downloads, plugins, upgrades and so on ...
Posted Sat 30 Aug 08 @ 1:52 pm
