Topic: Loop Problem
Hi im wonderin why does this happen
what i do is shorten th length on the loop from example from 16 take it down by pressing the button to eg. 8, but it doesnt go 8 4 2 etc. its goes straight to the sign of ?, and when i bring it back up to see if i can make it 4 it just goes 1 2 4, what is happening this error never happened before what the hell is going on? how can i fix this?
Posted Fri 29 Aug 08 @ 8:30 am
What button are you pressing? Are you using a controller?
No i just use a mouse, and i press the buttons under the Number of beats to shorten and lengthen th loop, just the one on the on screen (in program) mixer.
Which skin are you using?
