Forum: Old versions
Topic: One problem after another !!
I have to say I am spending a lot of time trying to get my setup working.
My latest problem is that I am getting feedback from the knobs like crackling sound from my MK 2 Console. I have installed all latest drivers, any ideas what could because this issue ?
Setup is IBM X31 with 1GB RAM, MK2 Console, Numark Power amp and two monitor speakers.
Posted Wed 27 Aug 08 @ 2:14 pm
Hello Marulos, are you running XP or Vista? There is a Vista patch Hercules has on their website. Did you download it and install it?
Posted Fri 29 Aug 08 @ 2:29 pm
jimmy bPRO InfinityMember since 2007
Try lowering your setting in the Performance tab of VirtualDJ config (if you can)
Posted Sat 30 Aug 08 @ 2:45 am
Elaborating on this...Go to config>performace - set the slider all the way to the left (fastest), untick "safe mode" and set latency to "auto." This ought to fix you up in good shape ;)
Posted Mon 01 Sep 08 @ 2:59 am
