Hi
Hope someone can help. Whilst doing a soundcheck before a gig the other night there was a power failure. My own fault but I did not have my UPS on my Xponent and that went down. My laptop continued but when I got everything going again I noticed that most the songs in my playlist had yellow ? marks and would give an error message when trying to load. If I check file info it says "file does not exist" and the file path has changed.
I only have 1 external drive with all my music and it has changed from "G" to "F", NOT the drive but the path in file info. The drive letter is still the same and only to certain songs not all of them, some still work ???
I have tried recursing, Check, Clean, Fix, re-scanned all and it still will not fix it.
The songs are still on my "G" drive but the playlist is messed up.
Is there anyway of fixing this without re-doing all the lists?
I know this all sounds a bit confusing but I'm confused as Im not 100% sure what happened.
Posted Wed 27 Aug 08 @ 5:06 am
Ok Fixed it, downloaded "DioneSS Playlist Editor 2.0" which searched and fixed my playlist all seems well now.
Posted Wed 27 Aug 08 @ 6:34 am
