As you know, some of the music you play does not have a video with it but you need to play it. The problem is that you have nothing on your screen. I have a Dancing girl video effect the can be used with clickbank plug in. This allows you to play your mp3's and still have something on the screen.
shadowdancers clip.swf
I can also add you logo to the video. Please contact me if you want ths done before ordering from the site. follow the direction on the page. I think the price is not bad.
www.digitalmixdj.com
Just a note we will be looking for DJs that use VDJ only to spin on our station soon
Posted Sun 24 Aug 08 @ 3:43 am
These have been around for awhile, and I own all of the DVDs(except the male dancers, hey sue me). Since I work in a gentlemen's club, I did not need that one. Doesn't the logo take away from the effect of the hot dancer?
Posted Sun 24 Aug 08 @ 3:54 am
no the logo is at the bottom of the video and can be a large or small as you need it to be. It can also spin if needed. Take a look at the spinning logo on www.digitalmixdj.com
Posted Sun 24 Aug 08 @ 4:05 am
And you can't post links to the clips as they are copyrighted.:)
Posted Sun 24 Aug 08 @ 5:25 am
Have to say that it looks like crap. Rotating text over shadow dancer with big empty rectangle behind rotating text. Theres plenty of programs that will do rotating text that you can save as a clip, and Virtual DJ allows you to overlay your clip over your videos with better look than what your showing us.
Posted Sun 24 Aug 08 @ 2:52 pm
Agreed...
Posted Sun 24 Aug 08 @ 2:59 pm
the guys have spoken, why not use png, it will give you a transparency effect with jpg, without blocking any part of the screen, and for mpg's if i hadn't been celebrating my brothers birthday i could have told you how to do a transparency there to, maybe's someone else can pipe in.
hic
up
hic
up
Posted Sun 24 Aug 08 @ 8:13 pm
sorry got to explain, only see my bruv once every three years...
Posted Sun 24 Aug 08 @ 8:19 pm
