OK. It seems every one who is using the RMX is staying with 5.1. Heres the thing when i intsalled 5.2 the performance of console seemed to be much improved from 5.1, except that you can't map the buttons. My question of course is how do you map the buttons in 5.2.........sorry if the answer has been posted, i could not find it.
Posted Fri 22 Aug 08 @ 2:47 am
You need to download the updated v5.2 RMX skin
Posted Fri 22 Aug 08 @ 8:36 am
Hi there,
Where could i find the skin please?
Would you have a nice link to put me there?
regards
Ben
regards
Ben
Posted Fri 22 Aug 08 @ 9:02 am
Could have done a search on the skins page for RMX, but I will be nice -- http://www.virtualdj.com/addons/skin.html?id=4554
Posted Fri 22 Aug 08 @ 10:06 am
Is it not possible to get a real mapper for the RMX??Like for the mk 1&2 where it`s possible to change every button -slider-knob`s
Posted Fri 22 Aug 08 @ 10:30 am
Thanks........Good Lookin Out! All is good, just don't like the new pitch bend
Posted Fri 22 Aug 08 @ 2:05 pm
I downloaded the skin, but I dont have an option to assign pitch bend to it. What am I missing?
-David
-David
Posted Fri 22 Aug 08 @ 3:31 pm
Download this skin http://www.virtualdj.com/addons/skin.html?id=4369 it looks better and you will be able to do what you want. BUT remember when you close the skin you will not be able to save your settings
Posted Sun 24 Aug 08 @ 4:30 am
