When I save a cue and I close the program the cue is saved, but when I re-cue it and close the program the part where I re-cued it from doesn't save. How do I fix this problem?
Posted Sat 16 Aug 08 @ 9:06 pm
what version(vdj)are you using and tell me if its vista or xp.
Posted Sun 17 Aug 08 @ 2:04 pm
check your config setting?
make sure auto cue save is enabled
Posted Sun 17 Aug 08 @ 3:43 pm
I'm running Vista.
Posted Sun 24 Aug 08 @ 7:12 pm
