has anyone had this problem that vdj doesnt allow all the effects that the ICDX has when playing cd's
is there a way to load them?
Posted Sat 16 Aug 08 @ 6:13 pm
Those effect only work when playing CDs. Never intended to work through VirtualDJ, it has it's own effects. This is the same for all the external table top controllers.
Posted Sat 16 Aug 08 @ 6:56 pm
that sux only reason i bought saw it on the vdj hardware , guess ill return it for 500 bucks the scratch is is not good and now with out extra effects not worth havn when the wireless mouse can do alll that
Posted Sat 16 Aug 08 @ 7:05 pm
Since your returning the iCDX I would suggest using the $500 dollars and purchase VDJ with it. VDJ works with a lot of different controllers.......
Posted Sat 16 Aug 08 @ 7:31 pm
what do you mean vdj works with alot of different controllers... and to buy a vdj?
Posted Sat 16 Aug 08 @ 7:41 pm
VDJ = VirtualDJ.....I was suggesting if you have 500 USD to invest 300USD and purchase VirtualDJ. VirtualDJ works with a wide range of controllers, and time codes.....
Posted Sat 16 Aug 08 @ 9:55 pm
