Topic: does anyone else have this problem with the Mk2?
i installed the latest driver for the mk2 consol. everything works fine, but i can't use the analog stick to browse up and down the tracks. for example, i drag down the analog stick, and it goes down once. and when i do it again, it wont go down again. can somebody help me find another solution to fix it. thnk you . very much appreciated
Posted Thu 14 Aug 08 @ 1:25 am
I've had the MK2 for a while now, but that's never happened to me.
do a clean install, it works wonders.
latest drivers...13.7 firmware I think.....everything works fine, x-ept 4 the jog stick......sounds like the console could be faulty, so why don't you download a midi monitor here and check to see the values for the jog wheel....if they don't seem right then u may have to exchange it.
guys where can i find the hercules mk2 mapper in xml format so i can load it in the midi?
