Forum: Old versions
Topic: Numark Cue/VDJ keeps crashing need help!
Hello, my VDJ keeps crashing a few times like 1 out of every 5 gigs. It does not warn you or anything, it just closes real fast. Please i need help on this. I run it on Vista. duo core 2.6 2 GB of ram. 256 video card. Please help me with this problem. Thank you. Here is my crash guard report.
Crash ID=004c6f3c (date=806162128, version=5.0.7, build=507, thread=Main, dump=8a0683c6, excode=c0000005 (0,61762635))
Crash ID=00474a51 (date=806201419, version=5.0.7, build=507, thread=Main, dump=8b421451, excode=c0000005 (0,5efb3a47))
Crash ID=00474a51 (date=806201824, version=5.0.7, build=507, thread=Main, dump=8b421451, excode=c0000005 (0,14))
Crash ID=00474a51 (date=806211943, version=5.0.7, build=507, thread=Main, dump=8b421451, excode=c0000005 (0,616f5270))
Crash ID=0e1f056a (date=806220005, version=5.0.7, build=507, thread=Main, dump=6f0ee07f, excode=c0000096)
Freeze (date=806281533, version=5.0.7, build=507, thread=SortThread)
Crash ID=00474a51 (date=806291708, version=5.0.7, build=507, thread=Main, dump=8b421451, excode=c0000005 (0,14))
Posted Wed 13 Aug 08 @ 1:31 am
It's the "invalid folder" crash problem.
It should be fixed in v5.2 but as you are a Cue user, you don't have it yet.
However, you can already download the version 5.1, which will be better for your problem.
I think I may have the same problem. Everytime I attempt to recurse folders or add folders to search DB.. the software crashes :-(
However I am using Virtual Vinyl and my latest update is 5.0.7 so how can "I" fix this???
No there is no link with your problem. I have answered you in the other topic.
