will the fasttrack pro work with the time code
Posted Fri 08 Aug 08 @ 1:18 pm
I don't think it will mate, you need a soundcard with 4 inputs and 4 output's like the M-audio conectiv or a maya 44
and by the look of the fasttrack pro it's only got the 4 outputs
Posted Fri 08 Aug 08 @ 1:28 pm
it says it has 4in and 4 out if it does do you think it will work
Posted Fri 08 Aug 08 @ 1:41 pm
I have it. It will not work with timecode. I does have 4in and 4out, but it's deceiving. They're including the MIDI in and the S/PDIF in as part of the inputs.
Posted Sat 09 Aug 08 @ 1:07 am
you can do single time code only
Posted Sat 09 Aug 08 @ 11:52 am
thanks to everyone for the info
Posted Sat 09 Aug 08 @ 12:13 pm
True... forgot about that option.
Posted Sun 10 Aug 08 @ 2:17 am
