Forum: Old versions
Topic: Successful 6+6 Button Mapping with VDJ 5.2 and Hercules RMX...
I made a registry edit that will map your 6+6 buttons on the Hercules Dj Console RMX as follows and will keep them mapped. This was tested successfully on Windows XP Pro SP2 with Virtual Dj Pro v5.2. Note that I had the "General Midi" remote control deactivated and I have no other midi controller being used concurrently. The edit will map you 6+6 button as follows:
Deck 1 and Deck 2:
Button1 = backspin
Button2 = loop_in
Button3 = flanger
Button4 = brake
Button5 = loop_out
Button6 = BeatGrid
Download Here
Save the file on your computer then double click load it into the registry.
If you want different mapping you can open the .reg file in any text editor (or just right-click on it and choose edit) and change the values to your pleasing.
Enjoy!
Posted Sat 02 Aug 08 @ 4:40 am
Just use the new RMX skin available on our website. You can directly select the sound effects for the 6 buttons
I think Cioce has a similar 6+6 config tool you can use aswell.
I didn't even realize there was one to d/l for the RMX. Thanks.
