Since vdj made the CDJ 400 native has there been any issues with it?
Does it work great????
Wanting to set up a new rig that consists of laptop 2 CDJ 400 U46dJ sound card and a midi mixer
currently i use timecode using 2 CD Axis 9 players and shuttle XP all fitted in a case (i play videos)
timecode play has treated me good so far... only a few issues now and then
always wanted to cut the timecode out of my setup so that i get the response and sound quality i did when i used the dac3 (on my first setup)
now dat pioneer has made CDJ 400 midi i wanted to know if it works well for owners with vdj. etc
cost of the CDJs compared to a Numark Axis is very different.. just need to know cause... i am not in a country that stocks them.. and there is not test return policy.. so ur responses would be greatly appreciated
Posted Tue 29 Jul 08 @ 7:27 pm
Until recently I owned a CDJ-400. As a CD player it is very good. As a controller it lacked, in my opinion, compared to the iCDX (which I own two of) for example. I am sure there are those who would argue that point, but to each his own.
Posted Tue 29 Jul 08 @ 8:06 pm
I'm really interested in the same setup as digitalwiz, so lets hear it guys...BLEACH IT OUT !!!
Posted Tue 29 Jul 08 @ 10:03 pm
hey TearEmUp could u tell me more bout ur findings with the ICDX?
Posted Sun 03 Aug 08 @ 9:27 am
Like what? I use two of them side by side, look at me blog for a picture, and love them A lot of control is available through the decks them selves. In tandem with my DXM01usb mixer it is a very nice set up indeed.
Posted Sun 03 Aug 08 @ 10:15 am
Are the jogwheels midi for either deck or is tccd necessary?
Posted Sun 03 Aug 08 @ 11:23 am
Yes, the jogs are midi, and just like in CD mode, push down on the center for scratching, or faster movements. The outside of the jogs can be used as a nudge feature, or there are nudge buttons for more precise beatmatching.
Posted Sun 03 Aug 08 @ 11:26 am
so u can only use one iCDx with vdJ at a time??
Posted Sun 03 Aug 08 @ 2:38 pm
No, you can use them two at a time, in tandem.
Posted Sun 03 Aug 08 @ 3:00 pm
just want to be sure........explain.. tandem.....
Posted Mon 04 Aug 08 @ 4:38 pm
Side by side, with a mixer in between...
Posted Mon 04 Aug 08 @ 4:44 pm
and this is not possible using the CDJ 400 in tandem???
Posted Sun 10 Aug 08 @ 4:39 pm
That I do not know, I only had one CDJ-400
Posted Sun 10 Aug 08 @ 7:18 pm
Yes two 400's can be used at once with vdj.
Posted Tue 12 Aug 08 @ 9:56 pm
I have used them both also and the ICDX has more native controllers over the VDJ feature like, samples, cuepoints, loops, effects,
where the 400 is limited. the 400 does have a scratch pad that is a little more sensitive but it's not close to a cdj 1000 so ummm
I think pioneer needs to go back and come again on this one.
Denon may have something in the 5500 but I don't think it's nativily support yet.
DJ SMG!
DJ SMG!
Posted Wed 13 Aug 08 @ 8:40 am
