Ok, Virtual Dj 5.0.7 just rocks on my new AMD 64 X2..... I was wanting to try using the webcam plugin along with my Hercules MK2. I have a Technics SL-1200MK2 and I am able to play vinyl in my mixes just fine (Setup is correct!). I have a Logitech Quickcam STX (it plugs in the USB port) and when I try to use the Webcam Remote Control I get an error that says "camera initialization failed". I know that there is a problem with USB 2.0 bandwidth unless you are using a PCI Express USB Card. Would that be my problem? I am not even sure how well the plugin works, but I would like to check it out.
Posted Mon 28 Jul 08 @ 8:16 pm
