Ok I have it hooked up working with video not problems. I hooked it up so that the crossfader controls the video and the audio inputs I used were the input 5 Audio In and PFL. I did this after seeing the youtube video by Kregz. I want to hook it up so I am still able to use my crossfader still to contol video but also take advantage of my curve control. The way it is hooked up now I can not use my curve control feature. Is there a way to do this? Basically I want to be able to have my curve contol and the midi crossfader both at the same time?
Posted Fri 25 Jul 08 @ 9:33 am
Would my mixer work with this program and allow me to use midi controls and curve crontrols on my mixer simultaniously? right now i am only able to use midi with no curve control or use curve control with no midi. I cant seem to hook it up so i am able to achieve both. anyone use this mixer?
Posted Fri 25 Jul 08 @ 2:16 pm
I use it but I don't have it hooked up the way you do.
I use the actual audio channels on the mixer to control the audio. I have the video crossfader set up for the crossfader on the mixer. Since I am using audio in the audio channels of the mixer I can control the curve of the crossfade for mixing audio.
Posted Fri 25 Jul 08 @ 6:10 pm
yes i seen the post on: http://www.virtualdj.com/forums/73631/General_Discussion/Nuo_4_users____I_Need_Help_With_Mapping__solved_.html?highlight=ecler%20nuo4
I want to be able to control both audio and video with the crossfader and also be able to use the curve control. is this possible or am I going to have to choose one or the other?
Posted Fri 25 Jul 08 @ 8:19 pm
