CAN SOMEONE HELP ME.... EVERY TIME I PLAY AN EFFECT ON ONE DECK..AND THEN I PLAY A EFFECT ON THE OTHER ONE THE OTHER STOPS....I MEAN ...WEN I PLAY THE SIREN....EXAMPLE. WHEN I CHOOSE SIREN ON ONE DECK...IT PLAYS ON BOTH...SO WEN I CHOOSE IT ON ONE AND PLAY IT AND I TRY CHOOSING A DIFFRENT ONE ON THE OTHER BOTH STOP!!! CAN SOME ONE HELP SO THIS WONT HAPPEN....I WANNA PLAY ONE ON ONE AND ANOTHER ON THE OTHER WHILE ONE IS PLAYING ALREADY...
Posted Tue 22 Jul 08 @ 11:17 am
Strange.
Each effect is indipendent from others so you can lauch several audio effects at the same time.
Anyway you can apply an audio effect only on Master Channel; it's not possible to apply an audio effect just on deck1 and another just on deck2
Posted Tue 22 Jul 08 @ 11:28 am
OK YEAH THATS WAT I MEANT....I APPLY ONE SAMPLER ON ONE SIDE NOT ON ONE DECK...BUT IF I APPLY ONSE SAMPLER ON ONE SIDE...THE OTHER SIDE ALSO PLAY THE SAME ONE. AND WHEN I TRY TAKING THE OTHER SIDE OFF AND PUTTIN A DIFFRENT ONE AT THE SAME TI,ME BOTH STOP......SO IF I DO WANT TO DO THIS....I HAVE TO PRE SELECT EACH ONE AND THEN PLAY THEM
Posted Tue 22 Jul 08 @ 11:54 am
I think that the sampler "buttons" on decks in the skins are linked. In other words, they are just used to point to the right sample in the sampler panel. If I'm not mistaken, they even change sample names together. To play multiple samples, then, I would just use the sampler panel itself and select "play" for each sample that you want to play at the same time.
Posted Tue 22 Jul 08 @ 12:01 pm
